I have a thermostat where I can set a holiday/party mode by sending a string containing the starting and ending time to an item. To select the starting and ending time a datetime picker would be nice. I am using OH2.
is there any custom widget implementing similar functionality?
if not, is there a way to add existing angular code so the HABpanel will automatically include the needed js files, or do I have to change the HAPpanel package, add the files, update web/index.html and create and install the updated jar?
Thanks for your hint. Right now I am experimenting with angular’s input[datetime], but I am failing at the requirement to initialize the value to new Date() necessary to start with the current date, which is something that the ng-init can’t do. Let’s see whether this one can do without it.
Looks like the inability to define controllers is a major drawback…
Hey Guys,
I just started to go a bit deeper with OH2 and are still struggeling with AngularJS.
I wanted to create a custom widget for picking up a time but the JS behind that isnt working.
First I installed the ui.bootstrap in /conf/htm/node_modules/angular-ui-bootstrap and made a “mycontroller.js” in /conf/html with:
