Debounce [3.2.0;3.4.9]
It’s not feasible for all rule templates to document the core process for installing and using a template. It is covered in the draft for the rules section of Getting Started and likely will be covered in other sections of the docs too.
Correct, when it changes to ON any debounce should be canceled since the only state debounced is OFF.
I’ll have to look into this. The log is showing that the timer should have been cancelled. “End debounce for PresenceProxyDebounced …”. But I’m not seeing the debug logs indicating that the timer actually was cancelled.
That’s the root of the problem.
