Never used that command and always called it karaf-console.
Sorry for that!
Back to your problem:
If you did raise and check the log level to DEBUG and do not see such lines, probably no such lines did probably appear in the timeframe you checked. ( is this binding installed, do you have devices using this protocol in your system?)
Yes,there more than 10 (for now only powersupplied devices)
and I can a see no entries (at least for 3 days) inside http://192.168.1.11:9001/
(or tail -f /var/log/openhab/openhab.log if you prefer it with ssh instead of http)
For this case I wanted to setup loglevel for script (because I can trigger that myself for sure) s.o.
For sure I get [info] [warning] [error] too from script. But not [DEBUG] after all.
(I remembered some issues that were solved after shutdown; but even this did not help here)
Can you post me your result of “log:get”
Just want to see, if that log4js is static or dynamicly growing if putting any line that is not there.
(as far as I know they are merge directives of some *.config files)
So do you had ANY line with this before or was it added?
Logging in as openhab
Password:
_ ___ ___ ___ | | | | / \ | __ )
/ _ \ / _ \ / _ \ / _ \ | |_| | / _ \ | _ \
| (_) | (_) | __/| | | || _ | / ___ \ | |_) )
\___/| __/ \___/|_| |_||_| |_|/_/ \_\|____/
|_| 3.2.0.M4 - Milestone Build
Use '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
To exit, use '<ctrl-d>' or 'logout'.
openhab> log:get
Logger │ Level
ROOT │ WARN
javax.jmdns │ ERROR
javax.mail │ ERROR
openhab.event │ INFO
openhab.event.AddonEvent │ ERROR
openhab.event.ChannelDescriptionChangedEvent │ ERROR
openhab.event.InboxUpdatedEvent │ ERROR
openhab.event.ItemAddedEvent │ ERROR
openhab.event.ItemChannelLinkAddedEvent │ ERROR
openhab.event.ItemChannelLinkRemovedEvent │ ERROR
openhab.event.ItemRemovedEvent │ ERROR
openhab.event.ItemStateEvent │ ERROR
openhab.event.RuleAddedEvent │ ERROR
openhab.event.RuleRemovedEvent │ ERROR
openhab.event.RuleStatusInfoEvent │ ERROR
openhab.event.StartlevelEvent │ ERROR
openhab.event.ThingAddedEvent │ ERROR
openhab.event.ThingRemovedEvent │ ERROR
openhab.event.ThingStatusInfoEvent │ ERROR
openhab.event.ThingUpdatedEvent │ ERROR
org.apache.cxf.jaxrs.sse.SseEventSinkImpl │ ERROR
org.apache.karaf.jaas.modules.audit │ INFO
org.apache.karaf.kar.internal.KarServiceImpl │ ERROR
org.apache.karaf.shell.ssh.SshUtils │ ERROR
org.apache.karaf.shell.support │ OFF
org.apache.sshd │ WARN
org.eclipse.lsp4j │ OFF
org.jupnp │ ERROR
org.openhab │ INFO
org.openhab.automation.script │ TRACE
org.openhab.binding.zwave │ INFO
org.openhab.core.model.script │ INFO
org.ops4j.pax.url.mvn.internal.AetherBasedResolver │ ERROR
org.ops4j.pax.web.pax-web-runtime │ OFF
su.litvak.chromecast.api.v2.Channel │ ERROR
openhab>
This is the state after a reboot. Don’t know wether that contains cached information as I have nothing to compare it against from before I executed your commands yesterday.
