Recently started with OpenHAB and am starting on debugging a few of the items I have that are not working correctly.
Recently installed four HunterDouglas blinds and these were discovered in OpenHAB, but are not responding to commands. Used the OpenHAB API page to query the blind position, but not able to control the blind.
The OpenHAB API generated this command:
curl -X POST --header "Content-Type: text/plain" --header "Accept: application/json" -d "UP" "http://pi01.groom.ch:8080/rest/items/LandingWindow_Position"
Response Code 200.
==> events.log <== 2018-10-28 11:10:36.184 [ome.event.ItemCommandEvent] - Item 'LandingWindow_Position' received command UP 2018-10-28 11:10:36.194 [nt.ItemStatePredictedEvent] - LandingWindow_Position predicted to become UP 2018-10-28 11:10:36.210 [vent.ItemStateChangedEvent] - LandingWindow_Position changed from 73 to 0 ==> openhab.log <== 2018-10-28 11:10:36.247 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.hdpowerview.internal.handler.HDPowerViewShadeHandler@1d2e81f': The template variable 'id' has no value java.lang.IllegalStateException: The template variable 'id' has no value at org.glassfish.jersey.client.JerseyWebTarget.getUri(JerseyWebTarget.java:134) ~[?:?] at org.openhab.binding.hdpowerview.internal.HDPowerViewWebTargets.invoke(HDPowerViewWebTargets.java:92) ~[?:?] at org.openhab.binding.hdpowerview.internal.HDPowerViewWebTargets.moveShade(HDPowerViewWebTargets.java:67) ~[?:?] at org.openhab.binding.hdpowerview.internal.handler.HDPowerViewShadeHandler.setPosition(HDPowerViewShadeHandler.java:114) ~[?:?] at org.openhab.binding.hdpowerview.internal.handler.HDPowerViewShadeHandler.setPosition(HDPowerViewShadeHandler.java:98) ~[?:?] at org.openhab.binding.hdpowerview.internal.handler.HDPowerViewShadeHandler.handleCommand(HDPowerViewShadeHandler.java:60) ~[?:?] at sun.reflect.GeneratedMethodAccessor380.invoke(Unknown Source) ~[?:?] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?] at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?] at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [101:org.eclipse.smarthome.core:0.10.0.oh240M4] at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [101:org.eclipse.smarthome.core:0.10.0.oh240M4] at com.sun.proxy.$Proxy165.handleCommand(Unknown Source) [220:org.openhab.binding.hdpowerview:2.4.0.M4] at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [107:org.eclipse.smarthome.core.thing:0.10.0.oh240M4] at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [107:org.eclipse.smarthome.core.thing:0.10.0.oh240M4] at sun.reflect.GeneratedMethodAccessor379.invoke(Unknown Source) ~[?:?] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?] at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?] at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [101:org.eclipse.smarthome.core:0.10.0.oh240M4] at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [101:org.eclipse.smarthome.core:0.10.0.oh240M4] at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:?] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:?] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:?] at java.lang.Thread.run(Thread.java:748) [?:?] Caused by: java.lang.IllegalArgumentException: The template variable 'id' has no value at org.glassfish.jersey.uri.UriTemplate$1ValuesFromArrayStrategy.valueFor(UriTemplate.java:1020) ~[?:?] at org.glassfish.jersey.uri.UriTemplate.resolveTemplate(UriTemplate.java:706) ~[?:?] at org.glassfish.jersey.uri.UriTemplate.createUriComponent(UriTemplate.java:1030) ~[?:?] at org.glassfish.jersey.uri.UriTemplate.createURIWithStringValues(UriTemplate.java:964) ~[?:?] at org.glassfish.jersey.uri.UriTemplate.createURIWithStringValues(UriTemplate.java:906) ~[?:?] at org.glassfish.jersey.uri.UriTemplate.createURI(UriTemplate.java:871) ~[?:?] at org.glassfish.jersey.uri.internal.JerseyUriBuilder._build(JerseyUriBuilder.java:914) ~[?:?] at org.glassfish.jersey.uri.internal.JerseyUriBuilder.build(JerseyUriBuilder.java:831) ~[?:?] at org.glassfish.jersey.client.JerseyWebTarget.getUri(JerseyWebTarget.java:132) ~[?:?] ... 22 more ==> events.log <== 2018-10-28 11:10:38.893 [vent.ItemStateChangedEvent] - LandingWindow_Position changed from 0 to 73
Where do I go next ?
regards
Steve
