I just begin to work with openHAB 1.8.3. Since we need generic rules, I tested Jython with a simple one, it worked well. OK, I then I translated a complicated DSL rule to Jython. After correcting the import errors, the rule (or a part of it) began to work and do something in execute. Unfortunately, there was an unknown identifier, so I got a Nameerror exception.
At this point I realized that the whole script is not parsed at the beginning for unknown identifiers, they only raise problem when the control gets there. I know it because this exception was thrown each time the cron triggered execution, but not immediately, so right after startup nothing happened.
This makes debugging extremely slow and painful, because I have to cover all execution paths with test cases. Is there a way to overcome this limitation?
What is the situation with Groovy? Does it parse the whole script fully after reading?
If not, is it possible in a simple way to wrap it in a Groovy program which imports everything openHAB would do, compile independently with a Groovy compiler to reveal all errors in just one pass?
Again about import errors: in Jython it was also awkward that it reported only one such error. After correcting it, there was a next one to be reported in the next openHAB startup. Starting it over and over for each error takes too much time. Do you know a better way to debug it?
However, does updating the file not automatically cause OH to reload the rules? With pretty much every other file changing it causes OH to automatically reload it. I don’t use JSR233 so don’t know if it fails to do that.
After some experiments I have found the solution: Groovy static compilation. This way all typos, type errors etc will be signed compile time. I have also found the solution for the script reload problem (it does happen with me with scripts in scripts directory): The JSR223 bundle must be reloaded using the r command on the OSGi console.
An example: this Groovy file, as a generic rule comes in scripts/lib:
Here ClazzLoader is a handy little class which is compiled and placed in scripts/lib. By including that directory in the openHAB class path the class file will be found.
class ClazzLoader {
static Class<?> parse(String name) {
GroovyClassLoader classLoader = new GroovyClassLoader();
return classLoader.parseClass(new File("configurations/scripts/lib/" + name));
