Hi
I’ve pretty much finished my Awair air quality sensor binding, but I had to force the precision of the temperature value to two decimal places in code:
return new QuantityType<>(new BigDecimal(value).setScale(2, RoundingMode.HALF_UP), stateUnit);
value
, which contains the temperature reading in this case, has a crazy level of precision (10 decimal places or more). The state unit is SIUnits.CELSIUS (when using metric measurements). The corresponding channel is defined in thing-types.xml
as follows:
<channel-type id="temperature">
<item-type>Number:Temperature</item-type>
<label>Temperature</label>
<description>Temperature</description>
<category>Temperature</category>
<state readOnly="true" pattern="%.2f %unit%"/>
</channel-type>
but the formatting seems to be ignored. I had the same problem with humidity, which came with a ton of decimals. Humidity has the state unit SmartHomeUnits.PERCENT. This is the channel definition:
<channel-type id="humidity">
<item-type>Number:Dimensionless</item-type>
<label>Humidity</label>
<description>Humidity level</description>
<category>Humidity</category>
<state readOnly="true" pattern="%.2f %%"/>
</channel-type>
I set the precision to zero in code in the same way as temperature.
Is this the right way to do it, or is there some other configuration somewhere? Thanks.
