I run openhabian with Openhab3 on rPi4.
Today I noticed the strange issue today on my smoke detectors. Among the other about 30 sensors, switches and lights I have also 5 Xiaomi Smoke detectors and two Heiman smoke detectors. The behaviour I notice on one Xiaomi Smoke detector and both Heiman detectors is the following:
- The REST gets updated, I could see the “lastupdated” tag changing when I pressed the test button of the sensor (paste from the REST is truncated with irrelevant data removed).
12: {
“lastseen”: “2021-01-12T11:53Z”,
“manufacturername”: “LUMI”,
“modelid”: “lumi.sensor_smoke”,
“name”: “Smoke Sensor Bedroom”,
“lastupdated”: “2021-01-12T11:53:53.907”,
22: { ..... "lastseen": "2021-01-12T11:15Z", "manufacturername": "Heiman", "modelid": "SmokeSensor-EM", "name": "Smoke Sensor Hall Up", ..... "lastupdated": "none",
9: { .... "lastseen": "2021-01-12T11:35Z", "manufacturername": "Heiman", "modelid": "SmokeSensor-EM", "name": "Smoke Sensor Hall Ground Floor", .... "lastupdated": "none", },
- On the Phoscon web application Heiman sensors remained with status unreachable even though the lastseen or lastupdated tags had timestamps from few minutes before
- The sensor is marked as GONE in the openhab and also the channels disappeared so I only could see two out of the 6 configured channels. And even on the remaining channels I could see the lastupdated received timestamp from the test few minutes back, but the sensor remained “GONE”
My channels & items are configured textually:
firesensor chSmokeDetectorHallGF "Smoke Detector Hall Ground floor" [ id="9", lastSeenPolling=720 ]
firesensor chSmokeDetectorBedroom "Smoke Detector Bedroom" [ id="12", lastSeenPolling=720 ]
firesensor chSmokeDetectorHallFF "Smoke Detector Hall First floor" [ id="22", lastSeenPolling=720 ]
Each sensor has the following item configuration:
//Smoke detector Bedroom
Group grpSmokeDetectorBedroom "Smoke Detector Bedroom" <smokeDetector> (grpBedroom, grpSmokeDetector)
Switch SmokeDetectorFireDetectedBedroom "Smoke detected" <fire> (grpSmokeDetectorBedroom) ["Smoke"] { channel="deconz:firesensor:conbeeII:chSmokeDetectorBedroom:fire"}
Number SmokeDetectorBatteryBedroom "Smoke Detector Battery" <battery> (grpSmokeDetectorBedroom) { channel="deconz:firesensor:conbeeII:chSmokeDetectorBedroom:battery_level" }
Switch SmokeDetectorBatteryLowBedroom "Smoke Detector Battery Low" <energy> (grpSmokeDetectorBedroom) { channel="deconz:firesensor:conbeeII:chSmokeDetectorBedroom:battery_low" }
Number:Temperature SmokeDetectorTemperatureBedroom "Smoke Detector Temperature [%.1f °C]" <temperature> (grpSmokeDetectorBedroom) { channel="deconz:firesensor:conbeeII:chSmokeDetectorBedroom:temperature" }
Switch SmokeDetectorTamperBedroom "Smoke Detector tamper" (grpSmokeDetectorBedroom) { channel="deconz:firesensor:conbeeII:chSmokeDetectorBedroom:tampered"}
DateTime SmokeDetectorLastUpdateBedroom "[%1$tY-%1$tm-%1$td %1$tH:%1$tM]" <clock-on> (grpSmokeDetectorBedroom) { channel="deconz:firesensor:conbeeII:chSmokeDetectorBedroom:last_updated" }
DateTime SmokeDetectorLastSeenBedroom "[%1$tY-%1$tm-%1$td %1$tH:%1$tM]" <clock-on> (grpSmokeDetectorBedroom) { channel="deconz:firesensor:conbeeII:chSmokeDetectorBedroom:last_seen" }
