- Platform information:
- Hardware:Raspi 3B plus
- OS: Debian 11 / raspios
- Java Runtime Environment: no clue, whatever comes with Openhab 4
- openHAB version: 4.0
Howdy folks, I have both openhab (reachable via port 8080) and the deconz app (reachable via the same IP, port 8081) running on my Raspy which is connected my local router, ensuring it is reachable via the local network for changing settings.
However, every time I turn off my router openhab stops working, loosing connection to the deconz gateway.
I mean I get it, its configured based on IP and the router is gone, may lead into issues, but…
a) after 10sec? really?
b) if I change the address to hostname “localhost” it seems to work for some time but then gets overwritten by IP address which then doesnt work anymore.
Did anyone experience the same?
Logs:
deconz:deconz:00212E095D5A’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Disconnected
Config:
UID: deconz:deconz:00212E095D5A
label: Phoscon-GW (192.168.0.17:8081)
thingTypeUID: deconz:deconz
configuration:
host: 192.168.0.17
apikey: deleted
httpPort: 8081
websocketTimeout: 120
timeout: 2000
