Openhab version: 3.2.0
buildString: Release Build
Deconz Binding
3.2.0
Deconz (gateway)Version : 2.13.04 (18/12/2021)
Hardware : Danfoss Ally TRV
Hi!
Ive been using the deconz binding for a while now and so far it has been working flawlessly. Today i purchased a Danfoss Ally Radiator valve and paired it to Deconz after which the openhab Inbox followed soon.
The valve is working and connected via Openhab. I get the readings from the device and am able to set the (target) temperature by sending a command thru channel:
deconz:thermostat:APIKEY:item:heatsetpoint
What i intend to do is close the valve when the window is open or when is heating is not wanted in a particular room (create zone heating thru OH). Also the childlock functionality is what i was hoping to implement. I am able to set these options thu the deconz rest api and the TRV closed the valve when the openwindow parameter is set. I could set these commands via the http binding but it would be great if these (put) commands could be implemented via the deconz binding!!?
Here’s the device with all its parameters from the api
"config": {
"battery": null,
"displayflipped": false,
"externalsensortemp": 0,
"externalwindowopen": false,
"heatsetpoint": 1622,
"locked": false,
"mountingmode": false,
"offset": 0,
"on": true,
"reachable": true,
"schedule": {},
"schedule_on": false
"ep": 1,
"etag": "ecc26fba3094aedf269923bc3e0f7903",
"lastannounced": null,
"lastseen": "2022-01-03T19:35Z",
"manufacturername": "Danfoss",
"modelid": "eTRV0100",
"name": "Thermostat",
"state": {
"errorcode": null,
"lastupdated": "2022-01-03T19:34:51.563",
"mountingmodeactive": false,
"on": false,
"temperature": 2345,
"valve": 0,
"windowopen": null
"type": "ZHAThermostat",
"uniqueid": "84:fd:27:ff:fe:d4:30:74-01-0201"
Put command for “window open” (closes valve to 0% when true until set to false) feature
“method”: “PUT”,
“transformRequest”: [
null
“transformResponse”: [
null
“jsonpCallbackParam”: “callback”,
“url”: “http://DECONZIP:80/api/KEY/sensors/ID/config”,
“headers”: {
“Accept”: “application/json, text/plain, /”,
“Content-Type”: “application/json;charset=utf-8”
“data”: “{ "externalwindowopen": true}”,
"time
Put command for “Child Lock”
“method”: “PUT”,
null
null
“headers”: {
“data”: “{ "locked": true}”,
“timeout”: {}
Is this anything worth implementing @J-N-K ? I would be very happy!
If i can provide any other info to make this work please let me know!!
