using OH 2.5.12 and deCONZ 2.9.2 latest beta
after clicking on IKEA switch and sending colorTemperature settings to zigbee lamp deconz bridge going offline
while watching in PaperUI the things table, the status of ALL deconz things changing in seconds to BRIDGE_OFFLINE / INITIALIZING / ONLINE again. some times many seconds OFFLINE. some times will stay at BRIDGE_OFFLINE for ever
having no network problems with RasbPi deconz phoscon - it’s always available.
i set timeout from 2000 to 4000 but not helping…
2021-02-12 15:28:58.381 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘0’, scaledValue = ‘0’
2021-02-12 15:28:58.387 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘254’, scaledValue = ‘100’
2021-02-12 15:28:58.390 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect ESH-httpClient-nz-deconz-homeserver$1500866216 to ws://192.168.42.207:443
2021-02-12 15:28:58.380 [INFO ] [smarthome.model.script.TradfriRemote] - amaris schalter dunkler - 100 hell
2021-02-12 15:28:58.394 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect ESH-httpClient-nz-deconz-homeserver$1500866216 to ws://192.168.42.207:443
2021-02-12 15:28:58.392 [DEBUG] [nternal.netutils.WebSocketConnection] - Trying to connect ESH-httpClient-nz-deconz-homeserver$1500866216 to ws://192.168.42.207:443
2021-02-12 15:28:58.402 [INFO ] [smarthome.model.script.TradfriRemote] - amaris schalter dunkler - 100 hell
2021-02-12 15:28:58.404 [DEBUG] [nternal.netutils.WebSocketConnection] - org.openhab.binding.deconz.internal.netutils.WebSocketConnection@597566a8 successfully connected to /192.168.42.207
2021-02-12 15:28:58.411 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘0’, scaledValue = ‘0’
2021-02-12 15:28:58.412 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘254’, scaledValue = ‘100’
2021-02-12 15:28:58.413 [DEBUG] [nternal.netutils.WebSocketConnection] - org.openhab.binding.deconz.internal.netutils.WebSocketConnection@597566a8 successfully connected to /192.168.42.207
2021-02-12 15:28:58.415 [DEBUG] [nternal.netutils.WebSocketConnection] - org.openhab.binding.deconz.internal.netutils.WebSocketConnection@597566a8 successfully connected to /192.168.42.207
2021-02-12 15:28:58.417 [DEBUG] [nternal.netutils.WebSocketConnection] - org.openhab.binding.deconz.internal.netutils.WebSocketConnection@597566a8 successfully connected to /192.168.42.207
2021-02-12 15:28:58.793 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘0’, scaledValue = ‘0’
2021-02-12 15:28:58.794 [DEBUG] [z.internal.handler.LightThingHandler] - val = ‘254’, scaledValue = ‘100’
2021-02-12 15:29:02.410 [DEBUG] [ernal.handler.DeconzBaseThingHandler] - Get new state failed:
java.util.concurrent.CompletionException: java.util.concurrent.TimeoutException: Total timeout 4000 ms elapsed
at java.util.concurrent.CompletableFuture.encodeThrowable(CompletableFuture.java:292) ~[?:1.8.0_201]
at java.util.concurrent.CompletableFuture.completeThrowable(CompletableFuture.java:308) ~[?:1.8.0_201]
at java.util.concurrent.CompletableFuture.uniApply(CompletableFuture.java:593) ~[?:1.8.0_201]
at java.util.concurrent.CompletableFuture$UniApply.tryFire(CompletableFuture.java:577) ~[?:1.8.0_201]
at java.util.concurrent.CompletableFuture.postComplete(CompletableFuture.java:474) [?:1.8.0_201]
at java.util.concurrent.CompletableFuture.completeExceptionally(CompletableFuture.java:1977) [?:1.8.0_201]
at org.openhab.binding.deconz.internal.netutils.AsyncHttpClient$1.onComplete(AsyncHttpClient.java:109) [bundleFile:?]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:198) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:190) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:444) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpReceiver.abort(HttpReceiver.java:527) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpChannel.abortResponse(HttpChannel.java:156) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpChannel.abort(HttpChannel.java:149) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpExchange.abort(HttpExchange.java:257) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpConversation.abort(HttpConversation.java:149) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpRequest.abort(HttpRequest.java:768) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.TimeoutCompleteListener.onTimeoutExpired(TimeoutCompleteListener.java:51) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.CyclicTimeout$Wakeup.run(CyclicTimeout.java:282) [bundleFile:9.4.20.v20190813]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_201]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_201]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_201]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_201]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_201]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_201]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_201]
Caused by: java.util.concurrent.TimeoutException: Total timeout 4000 ms elapsed
… 9 more
2021-02-12 15:29:02.432 [DEBUG] [ernal.handler.DeconzBaseThingHandler] - Get new state failed:
2021-02-12 15:30:08.475 [me.event.ThingUpdatedEvent] - Thing ‘deconz:switch:homeserver:00158d0003058b8b010012’ has been updated.
2021-02-12 15:30:08.475 [vent.ItemStateChangedEvent] - ZLED_color_amaris changed from 19.524834058136875,100,75 to 19.524834058136875,100,100
2021-02-12 15:30:08.476 [hingStatusInfoChangedEvent] - ‘deconz:deconz:homeserver’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Value must be between 0 and 100
2021-02-12 15:30:08.477 [hingStatusInfoChangedEvent] - ‘deconz:onofflight:homeserver:7cb03eaa0a022fbd03’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2021-02-12 15:30:08.477 [hingStatusInfoChangedEvent] - ‘deconz:onofflight:homeserver:7cb03eaa00ad375f03’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
only “openhab restart” will help.openhab-deconz-bridge_offline.txt (423.0 KB)
openhab-deconz-bridge_offline.txt (423.0 KB)events-deconz-bridge_offline-start.txt (815.0 KB)schalter.rules.txt (3.4 KB)
