I run OpenHAB 3.1 in docker on a RaspberryPi. Deconz is also running in docker on the same Raspberry Pi.
Today I noticed that all things connected to deconz are offline in OpenHAB with status “Bridge_Offline”.
The Phoscon-GW thing is saying:
**COMMUNICATION_ERROR**
Error while connecting: Insufficient configured threads: required=11 < max=10 for QueuedThreadPool[OH-httpClient--deconz-00212E05B211]@1589858{STARTED,5<=5<=10,i=1,r=-1,q=0}[ReservedThreadExecutor@77d243{s=0/1,p=0}]
The workaround works, but it is not sufficient on my opinion. I do not want to regularly check the UI and disable/enable the binding. I restart my Raspberry every night automatically and have sporadically the above mentioned issue.
Is there any way to increase the number of threads?
I run OH 3.1.0 inside Docker on a Raspberry Pi 2B.
After one restart, the problem seemed to be away now. I first tried it with “maxThreadsCustom=30” but then the error again appeared with requiring more than 30 threads. I have no idea whether 50 is a reasonable value for my small RPi 2B. -(")-
