Hi, I have a Conbee II and an aquaria switch QBKG12LM, a 2 way switch (with mains connection and direct control of to lines L1 and L2).
It works fine in the Phoscon app, it creates the switch and 2 transmitters in the lights section. I can see the events and switch on and off the lights controlled directly by the switch.
In openHAB I get 3 things, a switch (which only reports the events) a power and a consumption thing, but there is no way to know if the light is actually switched on or off, or to switch it on and off.
I get this messages in the console when I put the deCONZ bundle in DEBUG level.
23:30:22.333 [DEBUG] [ernal.discovery.ThingDiscoveryService] - Found light: lumi.ctrl_ln2.aq1 (Luz trastero), type UNKNOWN but no thing type defined for that type. This should be reported.
23:30:22.334 [DEBUG] [ernal.discovery.ThingDiscoveryService] - Found light: lumi.ctrl_ln2.aq1 (Luz trastero 2), type UNKNOWN but no thing type defined for that type. This should be reported.
In the documentation and in the message says I should report it so here it is.
Hi, I get the following error:
[ERROR] [org.openhab.binding.deconz ] - bundle org.openhab.binding.deconz:2.5.8.202008101428 (318)[org.openhab.binding.deconz.internal.DeconzHandlerFactory(295)] : Error during instantiation of the implementation object
java.lang.IllegalArgumentException: argument type mismatch
Some warnings also
[WARN ] [ig.xml.osgi.XmlDocumentBundleTracker] - The XML document ‘/ESH-INF/thing/sensor-thing-types.xml’ in module ‘org.openhab.binding.deconz’ could not be parsed: Supported itemType for a ChannelType must not be empty. : Supported itemType for a ChannelType must not be empty.
---- Debugging information ----
message : Supported itemType for a ChannelType must not be empty.
cause-exception : java.lang.IllegalArgumentException
cause-message : Supported itemType for a ChannelType must not be empty.
class : org.eclipse.smarthome.core.thing.xml.internal.ChannelTypeXmlResult
required-type : org.eclipse.smarthome.core.thing.xml.internal.ChannelTypeXmlResult
converter-type : org.eclipse.smarthome.core.thing.xml.internal.ChannelTypeConverter
path : /thing-descriptions/channel-type[8]
line number : 124
class[1] : java.util.ArrayList
converter-type[1] : com.thoughtworks.xstream.converters.collections.CollectionConverter
class[2] : org.eclipse.smarthome.core.thing.xml.internal.ThingDescriptionList
converter-type[2] : org.eclipse.smarthome.core.thing.xml.internal.ThingDescriptionConverter
version : not available
com.thoughtworks.xstream.converters.ConversionException: Supported itemType for a ChannelType must not be empty. : Supported itemType for a ChannelType must not be empty.
line number : 124
Hi, no errors or warnings now. The devices were still defined from the previous attempt and now I have the device offline anyway. I will test it this weekend and I will post here the results.
Thanks a lot.
I finished the electrical installation so the switch is back on-line.
It works. The rest of the devices I have also work with the snapshot plugin. I even added an extra water sensor and it also worked.
No warnings or errors.
