Hi all,
I have created a custom list widget that I wanted to use as a default widget for my window contacts.
Therefore I have set the default list widget in the item configuration:
The config of the widget is:
uid: list_item_window
tags:
- list
- window
props:
parameters:
- description: Human friendly service name
label: Service Name
required: false
type: TEXT
- context: item
description: An item to control
label: Item
required: false
type: TEXT
parameterGroups: []
timestamp: Feb 13, 2024, 8:18:58 PM
component: oh-label-item
icon: '=(items[props.item].state == "ON") ? "f7:window" : "f7:window"'
iconColor: '=(items[props.item].state == "ON") ? "green" : "red"'
title: =props.item
badge: '=(items[props.item].state === "CLOSED") & (items[props.item + "_Gekippt"].state === "CLOSED") ? "geschlossen" : ((items[props.item + "_Gekippt"].state === "CLOSED") ? "offen" : "gekippt")'
badgeColor: '=(items[props.item].state === "CLOSED") & (items[props.item + "_Gekippt"].state === "CLOSED") ? "green" : ((items[props.item + "_Gekippt"].state === "CLOSED") ? "red" : "orange")'
The widget is working as intended if I set the item manually:
Don’t know why there is a “-” at the end?
My main issue is that the item is not listed in the location where it is displayed, before the default widget was set:
With default widget set:
Without the default widget:
Has somebody any idea?
