Taking steps forward and want to leave the PaperUI behind me. Thats working ok but want to create real rules.
In Visual Studio code : made default.items and default.sitemap and all working fine.
But when creating the default.rules in the rules directory with below lines nothing happens.
Double checked and cannot find what is going wrong. Please help me to go forward.
import java.net.URI
rule “Entry”
Channel “zwave:device:512b1d8c:node4:sensor_door” changed from CLOSED to OPEN
Balkon_Lamp.sendCommand(ON)
I’m assuming you have an item setup for that channel? Check your item for your changes. Not all bindings support channel triggers. Your item state will do just as well.
Don’t blame you openhab is extremely powerful once opened up with text files when I first started I was petrified of text files soon realised how useful they were never looked back
I still use paper too install my bindings and create things the rest is text file now
Also when posting text rules and files can you use the code fences please it makes it alot eisier too read
Default.sitemap:
Text item=Hal_Voordeur label=“Voordeur”
Switch item=Balkon_Lamp label=“Lamp balkon”
The door is nicely showing a icon of an open door.
Switching the balcon light on works via mobile
Looks like the default.rules file is not read ??
(thanks for support uptill now).
Eager to make next step in programming. just want to start with simple rule. Perhaps you have something to check if default.rules is working ?
