Default sitemap not picked up by Basic UI
  • Platform information:
    • Hardware: CPUArchitecture/RAM/storage RPI 3
    • OS: what OS is used and which version Raspbian 10 Buster
    • Java Runtime Environment: which java platform is used and what version 11.0.9
    • openHAB version: openhab 2
  • Issue of the topic: default sitemap not picked up by Basic UI
So I created a default.sitemap in /etc/openhab2/sitemaps
sitemap default label=“My first sitemap”
Switch item=Switch=Bureau label=“Switch Bureau”
I have a items file.
The default was added to the BasicUI configuration, according to the tutorial https://www.openhab.org/docs/tutorial/sitemap.html
But BasicUI still says there is none configured.
What am I doing wrong? Everything else seems to work.
openHAB 2 requires Java 8, not 11.
I have just installed the java jdk (latest)
sudo apt install default-jdk
should I downgrade to 8?
pi@rpiCloudkey:/etc/openhab2/sitemaps $ java -version
openjdk version "11.0.9" 2020-10-20
OpenJDK Runtime Environment (build 11.0.9+11-post-Raspbian-1deb10u1)
OpenJDK Server VM (build 11.0.9+11-post-Raspbian-1deb10u1, mixed mode)
Certainly. openHAB 3 when it is released will use Java 11. For a RPI 3 Zulu Java is strongly recommended.
The easiest way for a Pi is to flash the latest openHABian image. It makes resolving dependencies much simpler and you should not run any other services on a Pi 3 anyway.
OK, I just thought I could run it on the same PI with the Unifi cloudkey in order to save up hardware and consumption, but I’ll set up a new one.
Do you by any chance have any idea what the default pasword is for the user pi on Openhabian? Doesn’t seem to be “raspberry”
openhabian:openhabian
You can still install unifi cloudkey on openHabian. Basically it is a Raspbian/Debian with some helper thingies for openHAB.
True but the developer, @mstormi strongly recommends against running much, especially on a Pi 3
