So If I run the following command on of my Yeelights to get the default white state of my Yeelights:
var String currentState = Yeelightc_7.state as HSBType
logInfo(filename,currentState.toString())
I get Hue = 0, saturation= 100, Brightness = 100
But If I send a command like this:
var HSBType weiss = new HSBType(new DecimalType(0),new PercentType(100),new PercentType(100))
Yeelightc_7.sendCommand(weiss.toString)
The Yeelights turn actually red, does someone noticed this weird behaviour or did someone managed to turn them to their default “bright white” state?
Thanks in advantage
note: I don’t really want to use the default Yeelight binding, since they’ve run perfectly with the robot vacuum binding …
I think this has to do with the colour mode setting.
If I recall well, the RGB is send, whereas you send a HSB.
You may try to change the colour mode first
