- Platform information:
- Hardware: Raspberry Pi 3
- OS: Openhabian
- openHAB version: 2.2
I am running OH2 on a raspberry (OpenHABian) and everything was fine with Version 2.1
After updating to Version 2.2, I realized a high delay of reactions to commands of devices.
If I e.g. turn on a light via a switch in the paper or classic UI, the device needs a long time (5sec up to some minutes!) to react.
Curiously, the reaction time increases the longer the system is running:
After a fresh reboot, everything is fine. After some days, it gets more and more lazy.
I also recognized, the CPU load increases. From 0.2% in average after a fresh boot up to 2% after some days.
The “top” command shows that the openhab process rises up to 120% load where it was around 20% after reboot.
What information is needed to analyse this issue? The normal log files are inconspicuous…
Thanks for your support!
