Delete old MQTT brokers
Well I finally got the MQTT binding to work in my openhab 2 instance.
But since i have messed around with a lot of different solutions, and had some troubles regarding old owner privileges, I installed and removed the MQTT binding a lot of times.
Now it’s working just fine, but in the logs I can see that all of the old different mqtt clients I tried using is still in there trying to connect to my mqtt broker.
I’ve tried restarting openhab, deleting the mqtt.cfg and restarting openhab again, nothing seems to work. I also tried upgrading from 2.1.0 to 2.2.0.
Any thoughts about how to reset something to get rid of the old connections??
This is output from my log
09:44:46.309 [INFO ] [rt.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker ‘broker’
09:44:56.319 [INFO ] [rt.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection ‘broker’
09:44:56.327 [ERROR] [rt.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
org.eclipse.paho.client.mqttv3.MqttException: Connection lost
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:146) [215:org.openhab.io.transport.mqtt:1.11.0.201709100109]
Caused by: java.io.EOFException
at java.io.DataInputStream.readByte(DataInputStream.java:267) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:65) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:107) ~[?:?]
… 1 more
09:44:56.329 [ERROR] [rt.mqtt.internal.MqttBrokerConnection] - MQTT connection to ‘mosquitto’ was lost: Connection lost : ReasonCode 32109 : Cause : null
I see that this topic: Mqtt: get rid of old config actually has the same problem as me. Anyway to get in somewhere and delete that old config files ?
Try This
First result will be
