For historical data rrd4j is used. The data is saved every minute. But deltaSince or historicState sometimes returns null. Any ideas why that is happening?
rule "Energie"
Time cron "0 * * * * ?"
var Number delta1 = Smartmeter_Energie.deltaSince(now.minusHours(1)) as Number
var Number past = Smartmeter_Energie.historicState(now.minusHours(1)).state as Number
var Number now = Smartmeter_Energie.state as Number
var Number delta2 = now - past
logWarn("test.rules", "Energy last hour: " + delta1 + " kWh (deltaSince) " + delta2 + " kWH (histotricState)")
The timestamp of your failing log entry is 8 seconds out of alignment with the rule trigger. Thatâs a clue that one of the retrievals has taken a long time, or more likely the deltaSince has just timed out.
Question; has a reboot happened in the previous hour or so? rrd4j will place âNaNâ into time-series pigeonholes where no per-minute persisting can have taken place, which can cause glitches later.
There was no reboot since a day. Also the system was untouched during night when this happens. I also checked the data in rrd file and also plotted the graph. I could not find a âNaNâ entry.
But during cheking the log i found that i only filtered for warning. There were also a few error due to null values of historicState.
All warning have a delay off a few minutes. But the historicState seams to have no delay.
Do you know how long it waits until a timout occur? Can it be increased?
I have set the log level to debug. But the value seams to be stored 50 ms before. What looks strange to me is that all entries have a second log entry with (again).
Remember rrd4j has an archive structure, with multiple tables for each Item, all representing the same times but more compressed. Iâve no idea if that is normal debug log, but the different messages (âagainâ) suggest it is expected.
Anyway, debug of that module didnât tell us anything about read activity. I donât know what to suggest to get âpersistence extensionsâ logging.
I tried to isolate the problem. Deactivated nearly every binding, transformation, ui,⊠Made the DSL rule also in Blockly and also in the new JS Scripting. All the same. But then i changed the timing to trigger 30 seconds later.
Seems a reasonable deduction. rrd4j has a fairly big job every minute.
Are you running with default âeverything you canâ settings? Might improve by selective persistence.
Of course what we really want is for your ad-hoc query to go in the work queue and give a result. Maybe itâs just timing out silently.
Before over 600 items werd stored in rrd4j, but currently only 50. But the intervall the null value happens was nearly the same on both configurations.
During my test before I have run three different language rules at the same time triggering every full minute. Sometimes one failed but the other both returned values and the difference of the logging where only 100 milliseonds more or less. I can also make it working with a second try when the first time a null is returned. So not sure why it should timout on one and not on the others.
Have you tidied away the unwanted rrd files? I donât know if will still carefully update/compress the archives as time marches on, it might keep populating the per-minute pigeonholes even if it is with NaN, Meaning it still processes 600 archives every minute.
The random nature of failure does not surprise me.
There was recent post about similar jdbc workload-related errors. It would be nice if the persistence service logged WARNs for timeouts, if that is what is happening.
After several hours of research I think i found the root cause. If the trigger overlaps with the timing when an archive in rrd4j is created (e.g. per default every hour, week, year, 5years and 10 years) it could happen that the persistance function returns null. I have tested this on different hardware and different operation system - everywhere the same.
PS:
When i changed the archive creation in rrd4j.cfg for example to 2 hours i have the null value with minusMinutes(120) and not anymore with minusMinutes(60).
Step to reprodice:
Make a timer with 0 * * * * ? * and the rule
var item = items.getItem("SmartmeterEnergie");
var beforeOneHour = time.ZonedDateTime.now().minusMinutes(60);
var todayEnergyConsumption = item.history.deltaSince(beforeOneHour, "rrd4j");
console.warn("Energy:", todayEnergyConsumption);
If it is not shown the null value you may retrigger the rule so it get recheduled and can execute at the same time the archive is created.
Would be nice if someone else can test and confirm thatâŠ
I think I follow what youâre saying. Say we have an archive configured for 2 hours, it will cover from now to 2 hours ago.
But - not exactly. We donât update it every millisecond, so sometimes it must cover a little less than 2 hours.
So if we come along and ask for data from 1:59 hours ago, it might or might not be in this nominally â2 hourâ archive. If we ask for 2 hours, it more than likely wonât be there yet. If we ask for 2:01 thatâs no problem - we look in the â8 hourâ archive instead.
There must be some code in the rrd4j persistence service that works out from the requested time which archive to look in. I guess that needs to made more cautious or clever.
