i’m new with OH2 but i got 2 z-wave devices to work and now i want to include also my denon avr3312 Reciever.
I installed the denon binding (binding-denon1 - 1.9.0) and the denon config under services includes:
It looks like the binding is successfully installed. Because it is a 1.x binding, your next step will be to create a .items file such as denon.items and put it in the conf/items/ folder.
Hi!
I have the same problem, there is no binding in PaperUI.
I generated a denon.item and a denon.sitemap file and filled them with the provided examples.
There is till no control panel anywhere
denon.cfg
#<instance>.<property>=value
# IP adress of the Denon receiver instance
avr3312.host=192.168.1.17
# Optional, set connection method for receiving updates. Can be http or telnet.
# Denon receivers only support one concurrent telnet connection, so use http if
# you have any other app using the telnet connection. Default = telnet
avr3312.update=http
# Optional, this sets the refresh interval (in milliseconds) for all instances
# if you're using the http connection method. Default = 5000
#refresh=5000
