OK ill start a new thread
Hi there,
I implemented the Time Of Day Design Pattern with only a few changes. It seems to work fine expect during the time from midnight to 5:59am in the morning when I get “UNKNOWN” instead of “Nacht”.
From 11pm to midnight I get the correct value “Nacht” but not afterwards.
What is wrong here? Did I miss anything?
rule "Calculate time of day state"
System started or // run at system start in case the time changed when OH was offline
Channel 'astro:sun:home:rise#event' triggered START or
Channel 'astro:sun:home:set#event' triggered START or
Time cron "0 1 0 * * ? *" or // one minute after midnight so give Astro time to calculate the new day's times
Time cron "0 0 6 * * ? *" or
Time cron "0 0 9 * * ? *" or
Time cron "0 0 12 * * ? *" or
Time cron "0 0 14 * * ? *" or
Time cron "0 0 18 * * ? *" or
Time cron "0 0 23 * * ? *"
logDebug(logName, "Calculating time of day...")
// Calculate the times for the static tods and populate the associated Items
// Update when changing static times
// Jump to tomorrow and subtract to avoid problems at the change over to/from DST
val morning_start = now.withTimeAtStartOfDay.plusDays(1).minusHours(18)
val forenoon_start = now.withTimeAtStartOfDay.plusDays(1).minusHours(15)
val noon_start = now.withTimeAtStartOfDay.plusDays(1).minusHours(12)
val afternoon_start = now.withTimeAtStartOfDay.plusDays(1).minusHours(10)
val evening_start = now.withTimeAtStartOfDay.plusDays(1).minusHours(6)
val night_start = now.withTimeAtStartOfDay.plusDays(1).minusHours(1)
val nextmorning_start = now.withTimeAtStartOfDay.plusDays(2).minusHours(18)
// Calculate the current time of day
Morgen: 6 bis 9 Uhr
Vormittag: 9 bis 12 Uhr
Mittag: 12 bis 14 Uhr
Nachmittag: 14 bis 18 Uhr
Abend: 18 bis 23 Uhr
Nacht: 23 bis 6 Uhr
var curr = "UNKNOWN"
switch now {
case now.isAfter(morning_start) && now.isBefore(forenoon_start) : curr = "Morgen"
case now.isAfter(forenoon_start) && now.isBefore(noon_start) : curr = "Vormittag"
case now.isAfter(noon_start) && now.isBefore(afternoon_start) : curr = "Mittag"
case now.isAfter(afternoon_start) && now.isBefore(evening_start) : curr = "Nachmittag"
case now.isAfter(evening_start) && now.isBefore(night_start) : curr = "Abend"
case now.isAfter(night_start) && now.isBefore(nextmorning_start) : curr = "Nacht"
// Publish the current state
logInfo(logName, "Calculated time of day is " + curr)
vTimeOfDay.sendCommand(curr)
I got the same issue few weeks ago. Try replacing && (and) by || (or). Current time cannot be between night start and next morning start. It’s only true before midnight…
This seems to work. Thanks a lot!
I’m a newbie in Programming, so I have a easy question. How is it possible to change the time for the switch, e.g. NIGHT starts at 22:00?
I already tried just typing
minusHours(2)
but that’s not changing the switching time away from 23:00. Same thing for DAY, wanna start it at 7:00 and not 6:00.
Can you help me?
As the OP states:
Adding a new time of day is as simple as adding a new trigger to the rule to fire when that time of day starts, calculate the DateTime for today when that time period starts, and then adding a new case to the switch statement to determine whether the current time is between when this new time period starts and the next one starts. The isBefore test for the previous time period would have to be updated as well.
So first you need to change the Rule trigger to run the Rule at 22:00 instead of 23:00.
Time cron "0 0 22 * *? *"
Then you need to change the line that determines night_start.
val night_start = now.withTimeAtStartOfDay.plusDays(1).minusHours(2)
You are not adding a new time period so you are done. Repeate for DAY.
hi i’m using this rule, but simplify for now, After some help (a alot) is runing, but the dawn trigger is not changing the items value.
DateTime Amanecer_civil "Astro: Amanecer Civil [%1$tH:%1$tM]" <time> { channel="astro:sun:casa:civilDawn#end" }
DateTime Atardecer_civil "Astro: Atardecer Civil [%1$tH:%1$tM]" <time> { channel="astro:sun:casa:civilDusk#start" }
val logName = "Momento del Dia"
rule "Dia y Noche"
System started or
Channel 'astro:sun:casa:civilDawn#event' triggered START or
Channel 'astro:sun:casa:civilDusk#event' triggered START
//Time cron " 0 0 0/1 1/1 * ? * "
Thread::sleep(1000)
logInfo(logName, "Calculando...")
val amanecer = new DateTime(Amanecer_civil.state.toString)
val atardecer = new DateTime(Atardecer_civil.state.toString)
Thread::sleep(1000)
switch now {
case now.isAfter(amanecer) && now.isBefore(atardecer): curr = "Dia"
case now.isAfter(atardecer) || now.isBefore(amanecer): curr = "Noche"
logInfo(logName, "El momento del dia es " + curr)
dia.sendCommand(curr)
I belive it must be something about the rule and the trigger happending together or something like that.
Any ideas.
You don’t seem to have accepted what I said before about that weird usage of switch-case
Sorry my mistake, i post it here becase i want to make my rule using this pattern son it can became more complex. You solution work, but i don’t want to make a lot of if and else (my professor will kill).
Also i want to understand why my rule is not working son i can learn for the next time.
Good day.
My TOD Worked and no it just does not update it any more.Did not change anything on my system.
TOD Items:
String vTimeOfDay "Current Time of Day [%s]" <tod>
DateTime vMorning_Time "Morning [%1$tH:%1$tM]" <sunrise>
DateTime vSunrise_Time "Day [%1$tH:%1$tM]" <sun> { channel="astro:sun:home:rise#start" }
DateTime vSunset_Time "Evening [%1$tH:%1$tM]" <sunset> { channel="astro:sun:home:set#start" }
DateTime vNight_Time "Night [%1$tH:%1$tM]" <moon>
DateTime vBed_Time "Bed [%1$tH:%1$tM]" <bedroom_blue>
DateTime vEvening_Time "Afternoon [ %1$tH:%1$tM]" <sunset> { channel="astro:sun:minus90:set#start" }
String Season "Season" { channel="astro:sun:home:season#name" }
Tod Site Map:
Frame label="TOD"{
Text label="Time of Day" icon="bedroom"{
Default item=vTimeOfDay label="Current Time of Day"
Default item=vSunrise_Time label="Day"
Default item=vSunset_Time label="Evening"
Default item=vMorning_Time label="Morning"
Default item=vEvening_Time label="Afternoon"
Default item=vNight_Time label="Night"
Default item=vBed_Time label="Bed"
Default item=Season label="Season"
TOD Log :
2020-05-25 10:22:29.389 [INFO ] [e.smarthome.model.script.Time Of Day] - Calculating time of day...
2020-05-25 10:22:29.465 [vent.ItemStateChangedEvent] - vMorning_Time changed from NULL to 2020-05-25T06:00:00.000+0200
2020-05-25 10:22:29.474 [vent.ItemStateChangedEvent] - vNight_Time changed from NULL to 2020-05-25T23:00:00.000+0200
2020-05-25 10:22:29.477 [vent.ItemStateChangedEvent] - vBed_Time changed from NULL to 2020-05-25T00:00:00.000+0200
2020-05-25 10:22:29.556 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule 'Calculate time of day state': Invalid format: "UNDEF"
==> /var/log/o
TOD Rule:
val logName = "Time Of Day"
Channel 'astro:sun:minus90:set#event' triggered START or
logInfo(logName, "Calculating time of day...")
vMorning_Time.postUpdate(morning_start.toString)
vNight_Time.postUpdate(night_start.toString)
val bed_start = now.withTimeAtStartOfDay
vBed_Time.postUpdate(bed_start.toString)
// Convert the Astro Items to Joda DateTime
val day_start = new DateTime(vSunrise_Time.state.toString)
val evening_start = new DateTime(vSunset_Time.state.toString)
val afternoon_start = new DateTime(vEvening_Time.state.toString)
switch now {
case now.isAfter(morning_start) && now.isBefore(day_start): curr = "MORNING"
case now.isAfter(day_start) && now.isBefore(afternoon_start): curr = "DAY"
case now.isAfter(afternoon_start) && now.isBefore(evening_start): curr = "AFTERNOON"
case now.isAfter(evening_start) && now.isBefore(night_start): curr = "EVENING"
case now.isAfter(night_start): curr = "NIGHT"
case now.isAfter(bed_start) && now.isBefore(morning_start): curr = "BED"
// Examples for use of vTimeOfDay
rule "Day time started"
Item vTimeOfDay changed to "DAY" // does not work prior to OH 2.3 Release
// do stuff when DAY starts
Not Sure where to look.
One or more of your Astro Items has an UNDEF state value. That’s not necessarily abnormal, depending on latitude and season. Inspect your relevant Item states to get further.
Find out.
Look in your events.log
for trigger events.
Look in your openhab.log
for the messages your rule produces.
Share that info with us.
Add further diagnostic logs to your rule, to see progress and to see key values, for example
logInfo(logName, "datetime...{}", amanecer)
logInfo(logName, "datetime...{}", atardecer)
Thank you.
Found my issue. it was the afternoon reading.
How do i get my Afternoon corected as it is the same as my evining time ?
Today morning logs are:
Events.log
2020-05-25 07:22:00.001 [vent.ChannelTriggeredEvent] - astro:sun:casa:civilDawn#event triggered START
2020-05-25 07:22:02.011 [ome.event.ItemCommandEvent] - Item 'dia' received command Noche
openhab.log
2020-05-25 07:22:01.005 [INFO ] [arthome.model.script.Momento del Dia] - Calculando...
2020-05-25 07:22:02.009 [INFO ] [arthome.model.script.Momento del Dia] - El momento del dia es Noche
My new rule is with logs is:
rule "Dia y Noche"
System started or
Thread::sleep(1000)
val ahora = new DateTime(now.toString)
Thread::sleep(1000)
logInfo(logName, "Amanecer: {}", amanecer)
logInfo(logName, "atardecer: {}", atardecer)
logInfo(logName, "ahora: {}", ahora)
switch now {
Two other things, first civildusk event work perfect, only civilDawn have has problems.
Second the trigger more times than it should and when it does run sevel times. I leave the logs.
events.log
2020-05-25 17:55:00.002 [vent.ChannelTriggeredEvent] - astro:sun:casa:civilDusk#event triggered START
The first two lines match the trigger event, everithing is perfect, the others run some minutes later and sevel times. This happens few times everyday.
openhab.log
2020-05-25 17:55:01.004 [INFO ] [arthome.model.script.Momento del Dia] - Calculando...
2020-05-25 17:55:02.007 [INFO ] [arthome.model.script.Momento del Dia] - El momento del dia es Noche
2020-05-25 17:59:19.375 [INFO ] [arthome.model.script.Momento del Dia] - Calculando...
2020-05-25 17:59:20.379 [INFO ] [arthome.model.script.Momento del Dia] - El momento del dia es Noche
2020-05-25 17:59:21.360 [INFO ] [arthome.model.script.Momento del Dia] - Calculando...
2020-05-25 17:59:22.364 [INFO ] [arthome.model.script.Momento del Dia] - El momento del dia es Noche
2020-05-25 18:16:18.935 [INFO ] [arthome.model.script.Momento del Dia] - Calculando...
2020-05-25 18:16:19.941 [INFO ] [arthome.model.script.Momento del Dia] - El momento del dia es Noche
2020-05-25 18:16:19.942 [INFO ] [arthome.model.script.Momento del Dia] - El momento del dia es Noche
2020-05-25 18:16:20.915 [INFO ] [arthome.model.script.Momento del Dia] - Calculando...
2020-05-25 18:16:21.920 [INFO ] [arthome.model.script.Momento del Dia] - El momento del dia es Noche
The most interesting thing about that. is the complete absence of three logInfo() outputs that are in the rule you show us.
The most likely explanation of that is either -
your last rules edit did not upload properly, an old version is still in use - check your openhab.log
for your xxx.rules file refresh message.
or
you have more than one rule with the same “name”. Only one will work.
Looks like you get multiple System started
events. That usually happens if you are editing files, and can also happen in some configuration situations. Look out for Thing updates (not Thing status updates) in your logs.
The first log are from this moorning and i edit the rules this afternoon. So new logs will be ready tomorrow morning.
Sorry.
Don’t know. What would you like it be?
I expect you want to apply an offset to your minus90
Thing?
Might help -
Hello Rich,
Having switched to openhab3, I noticed that the method for calculating time used in the Design Pattern is not supported anymore. Specifically, these lines:
The solution seems to be to use the Java Class ZonedDateTime, however, I am unable to figure out how that needs to be formatted exactly to be read by the openhab-items.
Does anyone have a hint on how to calculate the times for the “Time of Day” Design Pattern?
Thanks!
If you are on OH 3 I would recommend switching to the MainUI JavaScript implementation (link and description now in the top post). I don’t use Rules DSL any more and have not yet decided whether I’m going to go through all the DPs and update the Rules DSL versions for all of them. And the JavaScript and Python version are so much easier for you to use as is without code changes.
But the ZonedDateTime equivalent to that line of code would be
val morning_start = now.withHour(6)
That should handle the change in daylight savings without needing to jump forward than subtract back.
Rich,
thank you very much, I will have a look at the MainUI Javascript version (just as I was getting proficient in DSL rules…).
If I see this correctly, this is all driven by the different TimesOfDay items (Morning, Day, etc.), right? So I just need to figure out a way to populate those. Currently, I don’t think I have grasped the concept far enough to tell where that is done. Where or how do I define when Bedtime for a weekday is? Or for a weekend?
I’m not sure if that “How to boot strap the state of an Item” is what I need here.
I figured the ZoneDateTime variables out last night, but got stuck on importing the astro time in a correct format, kept getting all sorts of “cannot compare date” errors. So I’m definitively going to give the JavaScript a try.
Thanks!
