Weird. That doesn’t make much sense and it’s double weird that it’s working for me.
There is one thing that might be going on though, but I would expect slightly different behavior. Nashorn JavaScript is really tetchy about scope. I’m guessing that I’m not preserving the scope properly in the timer function that gets set.
Does it run again at 21:00 and say that it’s BED again instead of NIGHT, and then again at 22:00 and finally move to BED correctly?
Thank you for identifying this bug and helping me figure it out. It helps a lot!
Try this version of the Rule and see if that works better.
triggers:
- id: "1"
configuration:
groupName: TimesOfDay
type: core.GroupStateChangeTrigger
- id: "2"
configuration:
startlevel: 20
type: core.SystemStartlevelTrigger
- id: "4"
label: One minute after midnight
configuration:
time: 00:01
type: timer.TimeOfDayTrigger
conditions: []
actions:
- inputs: {}
configuration:
type: application/javascript
script: >
// Imports
var logger = Java.type("org.slf4j.LoggerFactory").getLogger("org.openhab.model.script.Rules.TimeOfDay");
scriptExtension.importPreset("default");
this.Ephemeris = (this.Ephemeris === undefined) ? Java.type("org.openhab.core.model.script.actions.Ephemeris") : this.Ephemeris;
this.ZonedDateTime = (this.ZonedDateTime === undefined) ? Java.type("java.time.ZonedDateTime") : this.ZonedDateTime;
// Get Metadata query stuff
this.FrameworkUtil = (this.FrameworkUtil === undefined) ? Java.type("org.osgi.framework.FrameworkUtil") : this.FrameworkUtil;
this._bundle = (this._bundle === undefined) ? FrameworkUtil.getBundle(scriptExtension.class) : this._bundle;
this.bundle_context = (this.bundle_context === undefined) ? this._bundle.getBundleContext() : this.bundle_context;
this.MetadataRegistry_Ref = (this.MetadataRegistry_Ref === undefined) ? bundle_context.getServiceReference("org.openhab.core.items.MetadataRegistry") : this.MetadataRegistry_Ref;
this.MetadataRegistry = (this.MetadataRegistry === undefined) ? bundle_context.getService(MetadataRegistry_Ref) : this.MetadataRegistry;
this.Metadata = (this.Metadata === undefined) ? Java.type("org.openhab.core.items.Metadata") : this.Metadata;
this.MetadataKey = (this.MetadataKey === undefined) ? Java.type("org.openhab.core.items.MetadataKey") : this.MetadataKey;
// Constants
var ETOD_ITEM = "TimeOfDay";
var ETOD_GROUP = "TimesOfDay";
var DAY_TYPES = ["default", "weekday", "weekend", "dayset", "holiday", "custom"];
var EXPECTED = "Invalid metadata for Item! "
+ "Expected metadata in the form of etod=\"STATE\"[type=\"daytype\", set=\"dayset\", file=\"uri\"] "
+ "where set is required if type is dayset and file is required if type is custom.";
var ETOD_NAMESPACE = "etod";
// Load TimerMgr
this.OPENHAB_CONF = (this.OPENHAB_CONF === undefined) ? java.lang.System.getenv("OPENHAB_CONF") : this.OPENHAB_CONF;
load(OPENHAB_CONF+'/automation/lib/javascript/community/timerMgr.js');
load(OPENHAB_CONF+'/automation/lib/javascript/community/timeUtils.js');
* Return the value or a key value from the Item's metadata
* @param {string} item name of the item
* @param {string} namespace metadata namespace to pull
* @param {string} key index into the configuration dict for the value
* @return {string} value assocaited with key or null if it doesn't exist.
var getValue = function(item, namespace, key) {
var md = MetadataRegistry.get(new MetadataKey(namespace, item));
if(md === null || md === undefined) {
return null;
else if(key === undefined) {
return md.value;
else {
return md.configuration[key];
* Verify Item and Item metadata
* @param {string} item name of the Item
* return {string} error string or null if the metadata checks out
var verifyMetadata = function(item) {
if(items[item].class == UnDefType.class) {
return "Item's state is " + items[items];
if(getValue(item, ETOD_NAMESPACE) === null) {
return "Item lacks metadata or metadata value.";
var type = getValue(item, ETOD_NAMESPACE, "type");
if(type === null) {
return "Item lacks a type key."
if(DAY_TYPES.indexOf(type) < 0) {
return type + " is not a valid day type, expected one of " + DAY_TYPES + ".";
if(type == "dayset" && getValue(item, ETOD_NAMESPACE, "set") === null) {
return type + " requires a 'set' value to be defined.";
if(type == "custom" && getValue(item, ETOD_NAMESPACE, "file")) {
return type + " requires a 'file' value to be defined.";
return null;
* Get a list of all the Items that have ephem metadata with type
* @param {java.util.List} etodItems collection of all the ETOD Items
* @param {string} type the type of day
* @return {java.util.List} those Items with a type metadata matching type
var getType = function(etodItems, type){
return etodItems.stream()
.filter(function(item){
return getValue(item.name, ETOD_NAMESPACE, "type") == type;
.toArray();
* Pull the set of Items for today based on Ephemeris
* @param {java.util.List} etodItems collection of all ETOD Items
* @return {java.util.List} only those Items defined for today's daytype
var getTodayItems = function(etodItems) {
Get the Items for today. Hierarchy is:
- custom
- holiday
- dayset
- weekend
- weekday
- default
var startTimes = {"default": getType(etodItems, "default"),
"weekday": (!Ephemeris.isWeekend()) ? getType(etodItems, "weekday") : [],
"weekend": (Ephemeris.isWeekend()) ? getType(etodItems, "weekend") : [],
"dayset": etodItems.stream()
.filter(function(item) {
return getValue(item.name, ETOD_NAMESPACE, "type") == "dayset"
&& Ephemeris.isInDayset(getValue(item.name, ETOD_NAMESPACE, "set"));
.toArray(),
"holiday": (Ephemeris.isBankHoliday()) ? getType(etodItems, "holiday") : [],
"custom": etodItems.stream()
return getValue(item.name, ETOD_NAMESPACE, "type") == "custom"
&& Ephemeris.isBankHoliday(0, getValue(item.name, ETOD_NAMESPACE, "file"));
.toArray()
var dayType = null;
if(startTimes["custom"].length > 0) {
dayType = "custom";
else if(startTimes["holiday"].length > 0) {
dayType = "holiday";
else if(startTimes["dayset"].length > 0) {
dayType = "dayset";
else if(startTimes["weekend"].length > 0) {
dayType = "weekend";
else if(startTimes["weekday"].length > 0) {
dayType = "weekday";
else if(startTimes["default"].length > 0) {
dayType = "default";
logger.info("Today is a " + dayType + " day.");
return (dayType === null) ? null : startTimes[dayType];
* Update Items to today
* @param {java.util.List} times list of all the ETOD Items for today
var moveTimes = function(times) {
var now = ZonedDateTime.now();
for each(var time in times) {
if(time.state.zonedDateTime.isBefore(now.withHour(0).withMinute(0).withSecond(0))) {
events.postUpdate(time.name, toToday(items[time.name]).toString());
logger.info("Moved " + time.name + " to today.");
* Create timers for all Items with a time in the future
* @param {java.util.List} times list of all the ETOD Items for todayu
var createTimers = function(times) {
var mostRecentTime = now.minusDays(1);
var mostRecentState = items[ETOD_ITEM];
for each (var time in times) {
var name = time.name;
var dt = time.state.zonedDateTime
var state = getValue(name, ETOD_NAMESPACE);
if(dt.isBefore(now) && dt.isAfter(mostRecentTime)) {
logger.debug("NOW: " + state + " start time " + dt + " is in the past "
+ " after " + mostRecentTime);
mostRecentTime = dt;
mostRecentState = state;
else if(dt.isAfter(now)) {
logger.debug("FUTURE: " + state + " scheduleing timer for " + dt);
timers.check(state, dt, etodTransitionGenerator(state));
else {
logger.debug("PAST : " + state + " start time of " + dt + " is before "
+ now + " and before " + mostRecentState + " " + mostRecentTime);
logger.debug("Created " + (Object.keys(this.timers.timers).length - 1) + " time of day timers");
logger.info("The current time of day is " + mostRecentState);
if(items[ETOD_ITEM] != mostRecentState) {
events.sendCommand(ETOD_ITEM, mostRecentState);
* Transition to a new Time of Day
* @TODO look into moving this to another rule we can call so it shows up in schedule
* @param {string} state the new time of day state
var etodTransitionGenerator = function(state) {
return function() {
logger.info("Transitioning Time fo Day from " + items[ETOD_ITEM] + " to " + state);
events.sendCommand(ETOD_ITEM, state);
// Main body of rule
this.timers = (this.timers === undefined) ? new TimerMgr() : this.timers;
// Skip if we have a flapping timer set
if(!this.timers.hasTimer("ephem_tod_rule")) {
// Check that all the required Items and Groups exist
if(items[ETOD_ITEM] === undefined) {
throw "The " + ETOD_ITEM + " Item is not defined!";
if(items[ETOD_GROUP] === undefined) {
throw "The " + ETOD_GROUP + " Group is not defined!";
var etodItems = ir.getItem("TimesOfDay").getMembers();
if(etodItems.size() == 0) {
throw ETOD_GROUP + " has no members!";
// Check the metadata for all the relevant Items
for each (var item in etodItems) {
var verify = verifyMetadata(item.name);
if(verify !== null) {
throw "Item " + item.name + ". " + EXPECTED + " " + verify;
// Get the time Items for today
var times = getTodayItems(etodItems);
if(times === null){
throw "No set of date times were found for today! Do you have a default set of date times?";
// Update the Items to today
moveTimes(times);
// Schedule a timer to wait for all the Items to update before creating the Timers.
this.timers.check("ephem_tod_rule",
"1s",
function() { createTimers(times);},
true,
function() { logger.info("Flapping timer, waiting before creating timers for time of day"); });
type: script.ScriptAction
The changes are minor. I changed the etodTransition function to return a function instead of creating an anonymous function when I create the function to call etodTransition. This will preserve the variable holding the state in the function’s context instead of relying on the global context.
Don’t worry, I don’t expect you to understand any of that. I’m mainly leaving it as a breadcrumb for future readers, including myself.
