Sorry for the tardy posting.
Here is another version of the rule that applies the same fix that is applied above to the creation of the flapping timer (I create a timer to wait until all the Astro Items or all the moved Items are updated before running the rule. Otherwise the rule could run a dozen times in a row, once for each DateTimeItem. While that wouldn’t be a problem, I don’t want to spam the logs.
triggers:
- id: "1"
configuration:
groupName: TimesOfDay
type: core.GroupStateChangeTrigger
- id: "2"
configuration:
startlevel: 20
type: core.SystemStartlevelTrigger
- id: "4"
label: One minute after midnight
configuration:
time: 00:01
type: timer.TimeOfDayTrigger
conditions: []
actions:
- inputs: {}
configuration:
type: application/javascript
script: >
// Imports
var logger = Java.type("org.slf4j.LoggerFactory").getLogger("org.openhab.model.script.Rules.TimeOfDay");
scriptExtension.importPreset("default");
this.Ephemeris = (this.Ephemeris === undefined) ? Java.type("org.openhab.core.model.script.actions.Ephemeris") : this.Ephemeris;
this.ZonedDateTime = (this.ZonedDateTime === undefined) ? Java.type("java.time.ZonedDateTime") : this.ZonedDateTime;
// Get Metadata query stuff
this.FrameworkUtil = (this.FrameworkUtil === undefined) ? Java.type("org.osgi.framework.FrameworkUtil") : this.FrameworkUtil;
this._bundle = (this._bundle === undefined) ? FrameworkUtil.getBundle(scriptExtension.class) : this._bundle;
this.bundle_context = (this.bundle_context === undefined) ? this._bundle.getBundleContext() : this.bundle_context;
this.MetadataRegistry_Ref = (this.MetadataRegistry_Ref === undefined) ? bundle_context.getServiceReference("org.openhab.core.items.MetadataRegistry") : this.MetadataRegistry_Ref;
this.MetadataRegistry = (this.MetadataRegistry === undefined) ? bundle_context.getService(MetadataRegistry_Ref) : this.MetadataRegistry;
this.Metadata = (this.Metadata === undefined) ? Java.type("org.openhab.core.items.Metadata") : this.Metadata;
this.MetadataKey = (this.MetadataKey === undefined) ? Java.type("org.openhab.core.items.MetadataKey") : this.MetadataKey;
// Constants
var ETOD_ITEM = "TimeOfDay";
var ETOD_GROUP = "TimesOfDay";
var DAY_TYPES = ["default", "weekday", "weekend", "dayset", "holiday", "custom"];
var EXPECTED = "Invalid metadata for Item! "
+ "Expected metadata in the form of etod=\"STATE\"[type=\"daytype\", set=\"dayset\", file=\"uri\"] "
+ "where set is required if type is dayset and file is required if type is custom.";
var ETOD_NAMESPACE = "etod";
// Load TimerMgr
this.OPENHAB_CONF = (this.OPENHAB_CONF === undefined) ? java.lang.System.getenv("OPENHAB_CONF") : this.OPENHAB_CONF;
load(OPENHAB_CONF+'/automation/lib/javascript/community/timerMgr.js');
load(OPENHAB_CONF+'/automation/lib/javascript/community/timeUtils.js');
* Return the value or a key value from the Item's metadata
* @param {string} item name of the item
* @param {string} namespace metadata namespace to pull
* @param {string} key index into the configuration dict for the value
* @return {string} value assocaited with key or null if it doesn't exist.
var getValue = function(item, namespace, key) {
var md = MetadataRegistry.get(new MetadataKey(namespace, item));
if(md === null || md === undefined) {
return null;
else if(key === undefined) {
return md.value;
else {
return md.configuration[key];
* Verify Item and Item metadata
* @param {string} item name of the Item
* return {string} error string or null if the metadata checks out
var verifyMetadata = function(item) {
if(items[item].class == UnDefType.class) {
return "Item's state is " + items[items];
if(getValue(item, ETOD_NAMESPACE) === null) {
return "Item lacks metadata or metadata value.";
var type = getValue(item, ETOD_NAMESPACE, "type");
if(type === null) {
return "Item lacks a type key."
if(DAY_TYPES.indexOf(type) < 0) {
return type + " is not a valid day type, expected one of " + DAY_TYPES + ".";
if(type == "dayset" && getValue(item, ETOD_NAMESPACE, "set") === null) {
return type + " requires a 'set' value to be defined.";
if(type == "custom" && getValue(item, ETOD_NAMESPACE, "file")) {
return type + " requires a 'file' value to be defined.";
return null;
* Get a list of all the Items that have ephem metadata with type
* @param {java.util.List} etodItems collection of all the ETOD Items
* @param {string} type the type of day
* @return {java.util.List} those Items with a type metadata matching type
var getType = function(etodItems, type){
return etodItems.stream()
.filter(function(item){
return getValue(item.name, ETOD_NAMESPACE, "type") == type;
.toArray();
* Pull the set of Items for today based on Ephemeris
* @param {java.util.List} etodItems collection of all ETOD Items
* @return {java.util.List} only those Items defined for today's daytype
var getTodayItems = function(etodItems) {
Get the Items for today. Hierarchy is:
- custom
- holiday
- dayset
- weekend
- weekday
- default
var startTimes = {"default": getType(etodItems, "default"),
"weekday": (!Ephemeris.isWeekend()) ? getType(etodItems, "weekday") : [],
"weekend": (Ephemeris.isWeekend()) ? getType(etodItems, "weekend") : [],
"dayset": etodItems.stream()
.filter(function(item) {
return getValue(item.name, ETOD_NAMESPACE, "type") == "dayset"
&& Ephemeris.isInDayset(getValue(item.name, ETOD_NAMESPACE, "set"));
.toArray(),
"holiday": (Ephemeris.isBankHoliday()) ? getType(etodItems, "holiday") : [],
"custom": etodItems.stream()
return getValue(item.name, ETOD_NAMESPACE, "type") == "custom"
&& Ephemeris.isBankHoliday(0, getValue(item.name, ETOD_NAMESPACE, "file"));
.toArray()
var dayType = null;
if(startTimes["custom"].length > 0) {
dayType = "custom";
else if(startTimes["holiday"].length > 0) {
dayType = "holiday";
else if(startTimes["dayset"].length > 0) {
dayType = "dayset";
else if(startTimes["weekend"].length > 0) {
dayType = "weekend";
else if(startTimes["weekday"].length > 0) {
dayType = "weekday";
else if(startTimes["default"].length > 0) {
dayType = "default";
logger.info("Today is a " + dayType + " day.");
return (dayType === null) ? null : startTimes[dayType];
* Update Items to today
* @param {java.util.List} times list of all the ETOD Items for today
var moveTimes = function(times) {
var now = ZonedDateTime.now();
for each(var time in times) {
if(time.state.zonedDateTime.isBefore(now.withHour(0).withMinute(0).withSecond(0))) {
events.postUpdate(time.name, toToday(items[time.name]).toString());
logger.info("Moved " + time.name + " to today.");
* Create timers for all Items with a time in the future
* @param {java.util.List} times list of all the ETOD Items for todayu
var createTimersGenerator = function(times, timers) {
return function() {
var mostRecentTime = now.minusDays(1);
var mostRecentState = items[ETOD_ITEM];
for each (var time in times) {
var name = time.name;
var dt = time.state.zonedDateTime
var state = getValue(name, ETOD_NAMESPACE);
if(dt.isBefore(now) && dt.isAfter(mostRecentTime)) {
logger.debug("NOW: " + state + " start time " + dt + " is in the past "
+ " after " + mostRecentTime);
mostRecentTime = dt;
mostRecentState = state;
else if(dt.isAfter(now)) {
logger.debug("FUTURE: " + state + " scheduleing timer for " + dt);
timers.check(state, dt, etodTransitionGenerator(state));
else {
logger.debug("PAST : " + state + " start time of " + dt + " is before "
+ now + " and before " + mostRecentState + " " + mostRecentTime);
logger.debug("Created " + (Object.keys(timers.timers).length - 1) + " time of day timers");
logger.info("The current time of day is " + mostRecentState);
if(items[ETOD_ITEM] != mostRecentState) {
events.sendCommand(ETOD_ITEM, mostRecentState);
* Transition to a new Time of Day
* @TODO look into moving this to another rule we can call so it shows up in schedule
* @param {string} state the new time of day state
var etodTransitionGenerator = function(state) {
return function() {
logger.info("Transitioning Time of Day from " + items[ETOD_ITEM] + " to " + state);
events.sendCommand(ETOD_ITEM, state);
// Main body of rule
this.timers = (this.timers === undefined) ? new TimerMgr() : this.timers;
// Skip if we have a flapping timer set
if(!this.timers.hasTimer("ephem_tod_rule")) {
// Check that all the required Items and Groups exist
if(items[ETOD_ITEM] === undefined) {
throw "The " + ETOD_ITEM + " Item is not defined!";
if(items[ETOD_GROUP] === undefined) {
throw "The " + ETOD_GROUP + " Group is not defined!";
var etodItems = ir.getItem("TimesOfDay").getMembers();
if(etodItems.size() == 0) {
throw ETOD_GROUP + " has no members!";
// Check the metadata for all the relevant Items
for each (var item in etodItems) {
var verify = verifyMetadata(item.name);
if(verify !== null) {
throw "Item " + item.name + ". " + EXPECTED + " " + verify;
// Get the time Items for today
var times = getTodayItems(etodItems);
if(times === null){
throw "No set of date times were found for today! Do you have a default set of date times?";
// Update the Items to today
moveTimes(times);
// Schedule a timer to wait for all the Items to update before creating the Timers.
this.timers.check("ephem_tod_rule",
"1s",
createTimersGenerator(times, this.timers),
true,
function() { logger.info("Flapping timer, waiting before creating timers for time of day"); });
type: script.ScriptAction
