Design Pattern: Looping Timers
What is the best way to implement a daemon process which runs always? I don’t want to start it in the “system startup” event because if I develop it I don’t want to restart the system in every minute. So I have created this cron below to start it. But if I change the code, I got I huge exception in the logs. I don’t have problem with that, but is this the best solution for it?
var Timer timer = null
rule "cron process"
	Time cron "0/10 * * * * ? *"
	if (timer === null)
		logInfo("cron", "start timer")
		timer = createTimer(now, [ |
        	//do the job here....
			timer.reschedule(now.plusMillis(200))
