I’m a relative beginner with Openhab, I did my first configs/rules at the beginning of the year, but have left it since around March due to a whole host of other things going on.
Anyway, I picked it up again at the weekend, and am setting about migrating some of the RFXCOM & lightwave configurations from my vera lite. I’ve hit a problem with items not being recognised/defined by Designer.
I’ve commented on another thread(1) about one of the instances, but having tried to look at the issue tonight with some pre-existing rules, I’ve got another list of errors reported by Designer, trigger by simply editing the file.
These rules have been working reliably for months, so I’m struggling to work out why they would suddenly cause errors.
Windows 10
Openhab 1.7.1 (Latest download on 20th Sept)
Openhab Designer 1.7.1 (latest download on 20th Sept)
C:>java -version
java version “1.8.0_60”
Java™ SE Runtime Environment (build 1.8.0_60-b27)
Java HotSpot™ 64-Bit Server VM (build 25.60-b23, mixed mode)
In the cases where you’re glueing together strings for logging purposes, what happens if you change the .state references into .state.toString…
I’m assuming the rule itself works, it’s just that the Designer is reporting/showing an issue with the syntax. If so, then there are other threads where the Designer doesn’t like valid that work at runtime and I wouldn’t overly worry about it.
