First, Thank you for a good job.
My problem is that I’m workimg mostly file based because of I’m reusing code on different sites.
On file based thing configuration learing is not possible as the property for naming the command is read only.
If I’ create the Thing (BroadLink RM4 Plus) in a file it works, but it canot learn as the properties of file based things are read only.
There should be a Item instead a property holding the name of the command to learn, or else the name can’t be set.
Otherwise, can a property of a file based thing be created or changed to read / write?
Thanks Ernst
