Is it possible to determine the element type (from a sitemap) that caused an item to receive a command?
For example I have an item:
Number Bedroom_Setpoint “Set Temperature [%.1f]”
And this is referenced in a sitemap as both a setpoint and a switch:
Setpoint item=Bedroom_Setpoint minValue=60 maxValue=80 step=1.0
Switch item=Bedroom_Setpoint mappings=[62=“Set Away”, 70=“Clear”]
In the rules file, I would like to do something different depending on whether or not Bedroom_Setpoint was updated via the Setpoint element or the Switch element. Is this possible?
Thank you.
