Sorry, it took so log for me to respond. Here is the rule I use to turn on the light:
rule "Check luminance"
Item Inside_Luminance changed
var Number start_time = 15
if(light_status.state.toString == "OFF"){
if(Season_Name.state.toString == "SUMMER" || Season_Name.state.toString == "SPRING"){
start_time = 16
if(now.getHourOfDay >= start_time) {
if(luminance_check_started.state == 0 || luminance_check_started.state == NULL){
var hourtime = start_time - 12
var current_status = "Check started at: " + hourtime.toString + ":00 PM, waiting for 0 luminance..."
executeCommandLine("/home/openhab/picode/ldr/set_luminance_start.py " + current_status)
luminance_check_started.postUpdate(1)
var Number luminance_level = Inside_Luminance.state as DecimalType
if( luminance_level <= 35 && DeskLight_Switch.state == OFF){
logInfo("luminance", "DeskLight ON")
logInfo("luminance", luminance_level.toString)
DeskLight_Switch.sendCommand(ON)
if(Inside_Luminance.state == 0 && (ZPorch_Switch.state == OFF ||
ZGarage_Switch.state == OFF)){
ZPorch_Switch.sendCommand(ON)
ZGarage_Switch.sendCommand(ON)
PatioLight_Switch.sendCommand(ON)
var String next_start = "Lights off when luminance '>' 0 next morning'...'"
executeCommandLine("/home/openhab/picode/ldr/set_light_status.py " + next_start)
executeCommandLine("/home/openhab/picode/ldr/side-level.py")
luminance_check_started.postUpdate(0)
As you can see, the rule is called every time there is a change in the luminance level, as detected by the multi sensor.
light_status
is an Item that is updated as outside lights toggle their state (OFF in the morning when luminance is > 0, ON by this rule, when luminance reaches 0)
The morning rule listed later.
Given the season, the rest of the rule will execute only if the current hour is past 3pm or 4pm. Once this threshold is met, the rest of the rule executes and updates the sitemap, and the Item
is updated to act as a guard to prevent multiple executions of execCommandLine. The luminance level is then checked and if the luminance level in is <= 35 AND the desk light is off, then the desk light will be turned ON.
Here is where the problem lies. If the light is on as a result of this rule, those log messages should appear in the log. But, today for example, here is what was in the log:
2018-06-12 16:00:02.183 [INFO ] [pse.smarthome.model.script.Desklight] - Received Command
2018-06-12 16:00:11.178 [INFO ] [lipse.smarthome.io.net.exec.ExecUtil] - executed commandLine '/home/openhab/picode/ldr/set_luminance_start.py Check started at: 4:00 PM, waiting for 0 luminance...'
As you can see, the Desklight got a "Received Command at 4:02, but the logging statements did not precede it. I have a logInfo statement in switch’s ‘received command’ rule. Today was an overcast day, so the luminance level was below 35, but even on sunny days, that light comes on at 4pm, except, of course, on the weekends. I don’t account for the day anywhere in the rule, so the discrepancy is strange.
I hope I’ve explained things well enough for someone to offer some insight. The rule for the desk lights ‘received command’ is simply:
rule "Adjust Desk lamp"
Item DeskLight_Switch received command
logInfo("Desklight", "Received Command")
if(receivedCommand == OFF){
Desk_Dimmer.sendCommand(OFF)
DeskLight_Switch.postUpdate(OFF)
else{
Desk_Dimmer.sendCommand(ON)
DeskLight_Switch.postUpdate(ON)
Here is the morning rule:
rule "Morning luminance check"
Item Inside_Luminance changed from 0
logInfo("Luminance", Inside_Luminance.state.toString)
if(light_status.state.toString == "ON"){
var start_time = 15
start_time = 16
var next_start = "Luminance check starting at: " + hourtime.toString + ":00 PM"
executeCommandLine("/home/openhab/picode/ldr/set_morning_light_status.py " + next_start)
ZPorch_Switch.sendCommand(OFF)
ZGarage_Switch.sendCommand(OFF)
I have one Time rule that turns on the light at 6:45 am during the work week:
rule "Turn on desk light during the work week at 6:45"
Time cron "0 45 6 ? * MON-FRI *"
logInfo("Desklight", "DeskLight morning ON command sent")
There are two other rules where the desk light gets sendCommand(ON), but those are both via two wall mote, and I can’t imagine those going rogue.
Someone mentioned turning on trace, I’ll have to look that up, as I’m not sure how to do that and I’ll get back with results.
Thanks for the help
