Still no luck, but i think there might be a general issue with zigbee2mqtt and this device
Look here…
I’ve tried alot since… The even more strange thing is that the interview goes fine and the device report no errors in the log untill i turn the “permit join” value from true to false and restart the zigbeetomqtt…
Jun 08 15:29:26 JIPI npm[6815]: zigbee2mqtt:info 2020-06-08 15:29:26: Device ‘0x0015bc00310022aa’ joined
Jun 08 15:29:26 JIPI npm[6815]: zigbee2mqtt:info 2020-06-08 15:29:26: Starting interview of ‘0x0015bc00310022aa’
Jun 08 15:29:26 JIPI npm[6815]: zigbee2mqtt:info 2020-06-08 15:29:26: MQTT publish: topic ‘zigbee2mqtt/bridge/log’, payload ‘{“type”:“device_connected”,“message”:{“friendly_name”:“0x0015bc00310022aa”}}’
Jun 08 15:29:26 JIPI npm[6815]: zigbee2mqtt:info 2020-06-08 15:29:26: MQTT publish: topic ‘zigbee2mqtt/bridge/log’, payload ‘{“type”:“pairing”,“message”:“interview_started”,“meta”:{“friendly_name”:“0x0015bc00310022aa”}}’
Jun 08 15:29:27 JIPI npm[6815]: zigbee2mqtt:info 2020-06-08 15:29:27: MQTT publish: topic ‘zigbee2mqtt/bridge/log’, payload ‘{“type”:“device_announced”,“message”:“announce”,“meta”:{“friendly_name”:“0x0015bc00310022aa”}}’
Jun 08 15:29:52 JIPI npm[6815]: zigbee2mqtt:info 2020-06-08 15:29:52: MQTT publish: topic ‘zigbee2mqtt/0x0015bc00310022aa’, payload ‘{“voltage”:3000,“battery_low”:false,“linkquality”:49,“enrolled”:false,“smoke”:false,“tamper”:false,“supervision_reports”:true,“restore_reports”:true,“trouble”:false,“ac_status”:false}’
Jun 08 15:29:53 JIPI npm[6815]: zigbee2mqtt:info 2020-06-08 15:29:53: Successfully interviewed ‘0x0015bc00310022aa’, device has successfully been paired
Jun 08 15:29:53 JIPI npm[6815]: zigbee2mqtt:info 2020-06-08 15:29:53: Device ‘0x0015bc00310022aa’ is supported, identified as: Develco Smoke detector with siren (SMSZB-120)
Jun 08 15:29:53 JIPI npm[6815]: zigbee2mqtt:info 2020-06-08 15:29:53: MQTT publish: topic ‘zigbee2mqtt/bridge/log’, payload ‘{“type”:“pairing”,“message”:“interview_successful”,“meta”:{“friendly_name”:“0x0015bc00310022aa”,“model”:“SMSZB-120”,“vendor”:“Develco”,“description”:“Smoke detector with siren”,“supported”:true}}’
Jun 08 15:34:48 JIPI npm[6815]: zigbee2mqtt:info 2020-06-08 15:34:48: MQTT publish: topic ‘zigbee2mqtt/0x0015bc00310022aa’, payload ‘{“voltage”:3000,“battery_low”:false,“linkquality”:42,“enrolled”:false,“smoke”:false,“tamper”:false,“supervision_reports”:true,“restore_reports”:true,“trouble”:false,“ac_status”:false}’
And after I set the Join option to false:
Jun 08 23:05:00 JIPI npm[23926]: zigbee2mqtt:error 2020-06-08 23:05:00: Failed to configure ‘0x0015bc00310022aa’, attempt 3 (Error: ConfigureReporting 0x0015bc00310022aa/35 genPowerCfg([{“attribute”:“batteryPercentageRemaining”,“minimumReportInterval”:3600,“maximumReportInterval”:62000,“reportableChange”:0}], {“timeout”:10000,“manufacturerCode”:null,“disableDefaultResponse”:true}) failed (Error: Status ‘UNSUPPORTED_ATTRIBUTE’)
Also tried to send the message as written while the join was enabled but still no alarm.
pi@JIPI:~ $ mosquitto_pub -t “zigbee2mqtt/0x0015bc00310022aa/35” -m “{“warning”:{“mode”:“burglar”,“level”:“high”,“strobe”:false,“duration”:300}}” -d
Client mosqpub|8650-JIPI sending CONNECT
Client mosqpub|8650-JIPI received CONNACK (0)
Client mosqpub|8650-JIPI sending PUBLISH (d0, q0, r0, m1, ‘zigbee2mqtt/0x0015bc00310022aa/35’, … (61 bytes))
Client mosqpub|8650-JIPI sending DISCONNECT
No success…
Any other suggestions on where to go from here ?
