Hi, this is a cross-post to https://www.eclipse.org/forums/index.php/t/1085686/ because I hope it is just a simple answer and I fear that the question might go unread/unanswered at eclipse, I hope that this is OK?
What is the correct Java method call for sending a command to another binding’s Channel, such that is is handled exactly as if someone had clicked in the UI?
I tried handleCommand() and postCommand() but they are not working as expected.
More detail is over at the ESH forum’s Thread.
Well, the use case sounds similar to a rule, but then it’s different:
I kind of want to substitute the “original binding’s” panel in PaperUI by my own binding’s panel, which should “mirror” specific other channels. And I got it completely working already with receiving values (numeric, boolean) but not with sending. The user should be spared with setting up logic, but instead only configures the channels to be mirrored.
