As part of trying to upgrade from 2.3 to 2.5 (currently m2) I thought I’d take a copy of my machine and upgrade it ( see the comment in here about upgrading: Running openHAB 2 in Docker)
What’s the best way of doing this?
Obviously the copied system won’t have everything, it won’t have zwave etc.
But I also don’t want it populating my main influxdb. But the more changes I make to the config the more chances I have that it becomes a pointless exercise as I kill my working system (eg make a change for my 2.5 system to remove persistence…and that makes it’s way to the live system when I finally upgrade).
So can I do something like set the influx config, to be the openhab-prod db for live, and openhab-dev for the testing system - automatically…ie use some sort of variable for the system that’s picked up (meaning I don’t actually have to change the config file)…same goes for mqtt client ids.
Hmm how good are you on git? Yes all these files will be in a branch. But any ideas how I can not commit the changes influxdb.cfg and mqtt.cfg (the two I can think of off the top of my head)
That’s easy. Create a .gitignore file and list each of those files, each on their own line. Here is an example of my .gitignore for my full conf/userdata repo which excludes all sorts of things.
Yeah I wanted something more than that…as I do want these files in git…so they need to be committed - but in the branch any changes to these files, I don’t want to merge them back to trunk…
I may have found a way:
Configure a merge driver that prioritises the trunk over the branch. Then add the specific files (mqtt.cfg, influxdb.cfg mqtt-eventbus.cfg at this stage) to the .gitattributes. That should mean in a merge, to trunk, that they’re ignored…hopefully. I’ll try it.
