Device Dishwasher - Card from ScrewPlate
ScrewPlate will be a template set with various widgets, all of which are highly customizable in a unified style. More information on GitHub
Here is a widget with which you can display the status of the device and the runtime.
You can select a point for the device status and then specify the expected value for the status, DONE, RUNNING and OFF yourself. If your device also displays the remaining runtime, you can also select the point for this or alternatively enter a fixed runtime. You can also increase the size of the appliance symbol by X %.
This card was inspired by @DrRSatzteilDishwasher Status
Screenshots
Changelog
In each widget there is a tag with version, please always make sure to use the latest version.
Change and further information on GitHub
Resources
https://raw.githubusercontent.com/DrScr3w/ScrewPlate/refs/heads/main/templates/Card_Template_Device_Dishwasher.yaml
