I’m using openhab 1.8.3 with:
- org.openhab.binding.zwave-1.9.0-SNAPSHOT.jar (1.9.0.201612160210).
- org.openhab.io.habmin-1.7.0-SNAPSHOT.jar (1.4.0.201504061533).
My device seems correctly detected as Node 4 but I cannot configure it. In GUI under Configuration > Bindings (ZWAVE - Z-Wave Binding) > Devices > “Node 4”, the nodes “Configuration Parameters” and “Association Groups” are empty, even after a refresh.
Device name is: Home Energy Meter - Gen 5
Model: ZW095-C (230V, 50Hz, EU/AU 1 phase). Model with 1 clamp.
The version existing in database is the version ZW095-A which is US model (120V, 60Hz, USA 2 phases).
I tried to upload my xml file as suggested in the Database Guide, but upload seems now disabled.
I attached my node4.xml and zwave.log (renamed to zwave.log.xml to be accepted as an attached file).
I think version 1 phase (1 clamp) and 3 phases 4 wires (3 clamps) are same model, only the number of clamps differs.
Documentation for the 3 phase version: http://products.z-wavealliance.org/ProductManual/File?folder=&filename=Manuals/2046/Home%20Energy%20Meter%20Gen5%20manual.pdf
Is it possible to add it in database?
In the zwave.log, there’s a stacktrace:
Caused by: java.lang.IllegalStateException: NODE 4: node wants to use security but key is not set
at org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveSecurityCommandClass.<init>(ZWaveSecurityCommandClass.java:342) ~[bundlefile:na]
Not sure it is important as data seemed to be received…
Olivier
node4.xml (3.3 KB)
zwave.log.xml (185.9 KB)
