Hi everyone,
Sorry for the continued posts, but I’m pulling my hair out.
I’ve now not only reset my hue bridge but, moved OpenHAB to a different machine, and canceled my whole little IPv6 adventure.
Nothing works, I really don’t understand it. I can ping the bridge’s IP from the OpenHAB box, so its not like there is a connection problem. Authentication, perhaps? I’ve moved things around so much I would have expected that OpenHAB asks me to press the button on the bridge again. But it doesn’t. Is there some way to force a clearing of the cache so that it does?
Apologies, long file coming next, but this is my log:
root@bedroompi02:/srv/heimatt/server# ./start_debug.sh
Launching the openHAB runtime in debug mode…
Listening for transport dt_socket at address: 8001
osgi> 14:44:52.565 [DEBUG] [.s.internal.SchedulerActivator:36 ] - Scheduler has been started.
14:44:52.790 [INFO ] [uartz.impl.StdSchedulerFactory:1175 ] - Using default implementation for ThreadExecutor
14:44:52.906 [INFO ] [rtz.core.SchedulerSignalerImpl:61 ] - Initialized Scheduler Signaller of type: class org.quartz.core.SchedulerSignalerImpl
14:44:52.909 [INFO ] [rg.quartz.core.QuartzScheduler:243 ] - Quartz Scheduler v.2.1.7 created.
14:44:52.919 [INFO ] [org.quartz.simpl.RAMJobStore :154 ] - RAMJobStore initialized.
14:44:52.928 [INFO ] [rg.quartz.core.QuartzScheduler:268 ] - Scheduler meta-data: Quartz Scheduler (v2.1.7) ‘openHAB-job-scheduler’ with instanceId 'NON_CLUSTERED’
Scheduler class: ‘org.quartz.core.QuartzScheduler’ - running locally.
NOT STARTED.
Currently in standby mode.
Number of jobs executed: 0
Using thread pool ‘org.quartz.simpl.SimpleThreadPool’ - with 2 threads.
Using job-store ‘org.quartz.simpl.RAMJobStore’ - which does not support persistence. and is not clustered.
14:44:52.932 [INFO ] [uartz.impl.StdSchedulerFactory:1324 ] - Quartz scheduler ‘openHAB-job-scheduler’ initialized from specified file: './etc/quartz.properties’
14:44:52.934 [INFO ] [uartz.impl.StdSchedulerFactory:1328 ] - Quartz scheduler version: 2.1.7
14:44:52.937 [INFO ] [rg.quartz.core.QuartzScheduler:534 ] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED started.
14:44:52.956 [DEBUG] [o.config.core.ConfigDispatcher:146 ] - Processing openHAB default configuration file ‘/srv/heimatt/server/configurations/openhab_default.cfg’.
14:44:52.960 [DEBUG] [o.config.core.ConfigDispatcher:168 ] - Processing openHAB main configuration file ‘/srv/heimatt/server/configurations/openhab.cfg’.
14:44:53.323 [DEBUG] [.o.core.internal.CoreActivator:93 ] - UUID file already exists at ‘/srv/heimatt/server/webapps/static/uuid’ with content '00136d1a-5f6d-47c7-b18a-5ebb64910a9c’
14:44:53.333 [DEBUG] [.o.core.internal.CoreActivator:115 ] - Created file ‘/srv/heimatt/server/webapps/static/version’ with content '1.8.1’
14:44:53.334 [INFO ] [.o.core.internal.CoreActivator:61 ] - openHAB runtime has been started (v1.8.1).
14:44:53.466 [DEBUG] [a.internal.AutoUpdateActivator:31 ] - AutoUpdate binding has been started.
14:44:57.974 [DEBUG] [.p.i.PersistenceModelActivator:23 ] - Registered ‘persistence’ configuration parser
14:44:58.054 [DEBUG] [.c.t.i.TransformationActivator:38 ] - Transformation Service has been started.
14:44:58.236 [DEBUG] [m.internal.MultimediaActivator:34 ] - Multimedia I/O bundle has been started.
14:44:58.347 [DEBUG] [.s.i.DiscoveryServiceActivator:27 ] - Discovery service has been started.
14:44:58.368 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl:93 ] - mDNS service has been started
14:44:58.758 [DEBUG] [.io.transport.mqtt.MqttService:123 ] - Starting MQTT Service…
14:44:59.047 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl:53 ] - Service Discovery initialization completed.
14:44:59.267 [DEBUG] [.i.internal.ItemModelActivator:24 ] - Registered ‘item’ configuration parser
14:44:59.685 [DEBUG] [o.o.c.i.items.ItemRegistryImpl:137 ] - Item provider ‘GenericItemProvider’ has been added.
14:45:02.741 [DEBUG] [.o.m.s.i.SitemapModelActivator:23 ] - Registered ‘sitemap’ configuration parser
14:45:03.154 [DEBUG] [io.rest.internal.RESTActivator:33 ] - REST API has been started.
14:45:03.526 [INFO ] [org.atmosphere.util.IOUtils :370 ] - META-INF/services/org.atmosphere.cpr.AtmosphereFramework not found in class loader
14:45:03.680 [INFO ] [sphere.cpr.AtmosphereFramework:2601 ] - Atmosphere is using org.atmosphere.cpr.DefaultAnnotationProcessor for processing annotation
14:45:03.685 [INFO ] [cpr.DefaultAnnotationProcessor:138 ] - AnnotationProcessor class org.atmosphere.cpr.DefaultAnnotationProcessor$BytecodeBasedAnnotationProcessor being used
14:45:03.770 [WARN ] [cpr.DefaultAnnotationProcessor:178 ] - Unable to detect annotations. Application may fail to deploy.
14:45:03.888 [INFO ] [sphere.cpr.AtmosphereFramework:1891 ] - Auto detecting atmosphere handlers /WEB-INF/classes/
14:45:03.978 [INFO ] [sphere.cpr.AtmosphereFramework:639 ] - Installed AtmosphereHandler org.atmosphere.handler.ReflectorServletProcessor mapped to context-path /* and Broadcaster Class org.atmosphere.jersey.JerseyBroadcaster
14:45:03.981 [INFO ] [sphere.cpr.AtmosphereFramework:1945 ] - Auto detecting WebSocketHandler in /WEB-INF/classes/
14:45:03.986 [INFO ] [sphere.cpr.AtmosphereFramework:1602 ] - Installed WebSocketProtocol org.atmosphere.websocket.protocol.SimpleHttpProtocol
14:45:04.192 [INFO ] [.a.h.ReflectorServletProcessor:103 ] - Installing Servlet com.sun.jersey.spi.container.servlet.ServletContainer
14:45:04.712 [INFO ] [c.s.j.s.i.a.WebApplicationImpl:815 ] - Initiating Jersey application, version 'Jersey: 1.18.1 02/19/2014 03:28 AM’
14:45:04.724 [INFO ] [c.s.j.s.i.a.WebApplicationImpl:826 ] - Adding the following classes declared in META-INF/services/jersey-server-components to the resource configuration:
class org.atmosphere.jersey.AtmosphereResourceConfigurator
14:45:04.986 [INFO ] [j.s.i.a.DeferredResourceConfig:101 ] - Instantiated the Application class org.openhab.io.rest.RESTApplication
14:45:06.828 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'bridge.sitemap’
14:45:07.719 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'default.sitemap’
14:45:08.125 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'groups.items’
14:45:08.215 [DEBUG] [i.internal.GenericItemProvider:154 ] - Processing binding configs for items from model 'groups.items’
14:45:08.227 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'groups.items’
14:45:08.263 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'hue.items’
14:45:08.399 [DEBUG] [i.internal.GenericItemProvider:154 ] - Processing binding configs for items from model 'hue.items’
14:45:08.414 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'groups.items’
14:45:08.417 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'hue.items’
14:45:08.449 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'media.items’
14:45:08.467 [DEBUG] [i.internal.GenericItemProvider:154 ] - Processing binding configs for items from model 'media.items’
14:45:08.471 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'groups.items’
14:45:08.474 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'hue.items’
14:45:08.478 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'media.items’
14:45:08.508 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'homematic.items’
14:45:08.574 [DEBUG] [i.internal.GenericItemProvider:154 ] - Processing binding configs for items from model 'homematic.items’
14:45:08.589 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'groups.items’
14:45:08.592 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'hue.items’
14:45:08.596 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'media.items’
14:45:08.598 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'homematic.items’
14:45:08.633 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'sensors.items’
14:45:08.648 [DEBUG] [i.internal.GenericItemProvider:154 ] - Processing binding configs for items from model 'sensors.items’
14:45:08.650 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'groups.items’
14:45:08.653 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'hue.items’
14:45:08.656 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'media.items’
14:45:08.659 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'homematic.items’
14:45:08.664 [DEBUG] [i.internal.GenericItemProvider:133 ] - Read items from model 'sensors.items’
14:45:09.396 [INFO ] [sphere.cpr.AtmosphereFramework:2435 ] - AtmosphereInterceptor CORS Interceptor Support will always be executed first
14:45:09.399 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor CORS Interceptor Support with priority FIRST_BEFORE_DEFAULT
14:45:09.402 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Default Response’s Headers Interceptor with priority AFTER_DEFAULT
14:45:09.410 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Android Interceptor Support with priority AFTER_DEFAULT
14:45:09.416 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor SSE Interceptor Support with priority AFTER_DEFAULT
14:45:09.420 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor JSONP Interceptor Support with priority AFTER_DEFAULT
14:45:09.427 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Atmosphere JavaScript Protocol with priority AFTER_DEFAULT
14:45:09.431 [INFO ] [sphere.cpr.AtmosphereFramework:2404 ] - Installed AtmosphereInterceptor Browser disconnection detection with priority AFTER_DEFAULT
14:45:09.447 [INFO ] [sphere.cpr.AtmosphereFramework:935 ] - Using EndpointMapper class org.atmosphere.util.DefaultEndpointMapper
14:45:09.453 [WARN ] [sphere.cpr.AtmosphereFramework:941 ] - No BroadcasterCache configured. Broadcasted message between client reconnection will be LOST. It is recommended to configure the org.atmosphere.cache.UUIDBroadcasterCache
14:45:09.455 [INFO ] [sphere.cpr.AtmosphereFramework:949 ] - Default Broadcaster Class: org.atmosphere.jersey.JerseyBroadcaster
14:45:09.457 [INFO ] [sphere.cpr.AtmosphereFramework:950 ] - Broadcaster Polling Wait Time 100
14:45:09.459 [INFO ] [sphere.cpr.AtmosphereFramework:951 ] - Shared ExecutorService supported: true
14:45:09.461 [INFO ] [sphere.cpr.AtmosphereFramework:958 ] - Messaging Thread Pool Size: 10
14:45:09.463 [INFO ] [sphere.cpr.AtmosphereFramework:968 ] - Async I/O Thread Pool Size: 10
14:45:09.465 [INFO ] [sphere.cpr.AtmosphereFramework:979 ] - Using BroadcasterFactory: org.atmosphere.cpr.DefaultBroadcasterFactory
14:45:09.467 [INFO ] [sphere.cpr.AtmosphereFramework:980 ] - Using WebSocketProcessor: org.atmosphere.websocket.DefaultWebSocketProcessor
14:45:09.469 [INFO ] [sphere.cpr.AtmosphereFramework:990 ] - Invoke AtmosphereInterceptor on WebSocket message true
14:45:09.471 [INFO ] [sphere.cpr.AtmosphereFramework:991 ] - HttpSession supported: false
14:45:09.473 [INFO ] [sphere.cpr.AtmosphereFramework:993 ] - Atmosphere is using DefaultAtmosphereObjectFactory for dependency injection and object creation
14:45:09.475 [INFO ] [sphere.cpr.AtmosphereFramework:994 ] - Atmosphere is using async support: org.atmosphere.container.JettyAsyncSupportWithWebSocket running under container: jetty/8.1.3.v20120522 with WebSocket enabled.
14:45:09.483 [INFO ] [sphere.cpr.AtmosphereFramework:996 ] - Atmosphere Framework 2.2.5 started.
14:45:09.485 [INFO ] [sphere.cpr.AtmosphereFramework:998 ] -
For Atmosphere Framework Commercial Support, visit
http://www.async-io.org/ or send an email to support@async-io.org
14:45:09.490 [INFO ] [penhab.io.rest.RESTApplication:144 ] - Started REST API at /rest
14:45:09.496 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:66 ] - Registering new service _openhab-server._tcp.local. at port 8080
14:45:12.190 [DEBUG] [o.o.i.s.i.DiscoveryServiceImpl:66 ] - Registering new service _openhab-server-ssl._tcp.local. at port 8443
14:45:15.128 [INFO ] [.o.u.w.i.servlet.WebAppServlet:80 ] - Started Classic UI at /classicui/openhab.app
14:45:16.475 [DEBUG] [.r.internal.RuleModelActivator:42 ] - Registered ‘rules’ configuration parser
14:45:16.532 [DEBUG] [m.r.internal.engine.RuleEngine:77 ] - Started rule engine
14:45:19.016 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'office.rules’
14:45:19.804 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'kitchen.rules’
14:45:19.931 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'livingroom.rules’
14:45:20.115 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'bedroom.rules’
14:45:20.229 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'balcony.rules’
14:45:20.281 [INFO ] [c.internal.ModelRepositoryImpl:80 ] - Loading model 'hallway.rules’
14:45:21.021 [DEBUG] [.a.t.internal.TwitterActivator:34 ] - Twitter action has been started.
14:45:21.159 [DEBUG] [.m.i.MyOpenHABServiceActivator:28 ] - MyOpenHAB service has been started.
14:45:21.169 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:300 ] - setEventPublisher
14:45:21.171 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:135 ] - my.openHAB service activated
14:45:21.174 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:118 ] - config is null
14:45:21.179 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:176 ] - UUID file found at ‘/srv/heimatt/server/webapps/static/uuid’ with content '00136d1a-5f6d-47c7-b18a-5ebb64910a9c’
14:45:21.183 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:228 ] - Secret file already exists at ‘/srv/heimatt/server/webapps/static/secret’ with content 'ocsfB8d3emOXNtfBcudb’
14:45:21.183 [DEBUG] [.p.internal.PersistenceManager:146 ] - Initializing myopenhab persistence service.
14:45:21.185 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:120 ] - UUID = 00136d1a-5f6d-47c7-b18a-5ebb64910a9c, secret = ocsfB8d3emOXNtfBcudb
14:45:21.201 [DEBUG] [c.internal.ModelRepositoryImpl:64 ] - Configuration model ‘myopenhab.persist’ can not be found
14:45:21.226 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:176 ] - UUID file found at ‘/srv/heimatt/server/webapps/static/uuid’ with content '00136d1a-5f6d-47c7-b18a-5ebb64910a9c’
14:45:21.228 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:228 ] - Secret file already exists at ‘/srv/heimatt/server/webapps/static/secret’ with content 'ocsfB8d3emOXNtfBcudb’
14:45:21.232 [DEBUG] [o.o.i.m.i.MyOpenHABServiceImpl:162 ] - Version file found at ‘/srv/heimatt/server/webapps/static/version’ with content '1.8.1’
14:45:21.247 [DEBUG] [o.b.h.i.bus.HomematicActivator:33 ] - Homematic binding has been started.
14:45:21.268 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘dimmer_officecouch (Type=DimmerItem, State=Uninitialized)’ with ‘HomematicGenericBindingProvider’ reader.
14:45:21.357 [DEBUG] [omematicGenericBindingProvider:63 ] - Adding item dimmer_officecouch with DatapointConfig[address=JEQ0348610,channel=1,parameter=LEVEL]
14:45:21.360 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘dimmer_hallway (Type=DimmerItem, State=Uninitialized)’ with ‘HomematicGenericBindingProvider’ reader.
14:45:21.363 [DEBUG] [omematicGenericBindingProvider:63 ] - Adding item dimmer_hallway with DatapointConfig[address=JEQ0348625,channel=1,parameter=LEVEL]
14:45:21.365 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘dimmer_tubelights (Type=DimmerItem, State=Uninitialized)’ with ‘HomematicGenericBindingProvider’ reader.
14:45:21.368 [DEBUG] [omematicGenericBindingProvider:63 ] - Adding item dimmer_tubelights with DatapointConfig[address=JEQ0646748,channel=1,parameter=LEVEL]
14:45:22.622 [INFO ] [.service.AbstractActiveService:169 ] - Exec Refresh Service has been started
14:45:22.635 [DEBUG] [.b.mqtt.internal.MqttActivator:34 ] - MQTT binding has been started.
14:45:22.732 [DEBUG] [m.internal.MqttEventBusBinding:68 ] - MQTT: Activating event bus binding.
14:45:22.749 [DEBUG] [.a.internal.bus.AstroActivator:32 ] - Astro binding has been started.
14:45:22.862 [DEBUG] [.b.http.internal.HttpActivator:34 ] - HTTP binding has been started.
14:45:22.935 [INFO ] [.service.AbstractActiveService:169 ] - HTTP Refresh Service has been started
14:45:22.948 [DEBUG] [.m.internal.MqttitudeActivator:33 ] - Mqttitude binding has been started.
14:45:23.008 [DEBUG] [.b.m.internal.MqttitudeBinding:84 ] - Activating Mqttitude binding
14:45:23.147 [DEBUG] [.o.internal.OpenPathsActivator:33 ] - OpenPaths binding has been started.
14:45:23.225 [DEBUG] [.o.b.hue.internal.HueActivator:30 ] - Hue binding has been started.
14:45:23.268 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Toggle_1 (Type=SwitchItem, State=Uninitialized)’ with ‘HueGenericBindingProvider’ reader.
14:45:23.275 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Toggle_2 (Type=SwitchItem, State=Uninitialized)’ with ‘HueGenericBindingProvider’ reader.
14:45:23.278 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Toggle_3 (Type=SwitchItem, State=Uninitialized)’ with ‘HueGenericBindingProvider’ reader.
14:45:23.281 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Toggle_4 (Type=SwitchItem, State=Uninitialized)’ with ‘HueGenericBindingProvider’ reader.
14:45:23.284 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Toggle_5 (Type=SwitchItem, State=Uninitialized)’ with ‘HueGenericBindingProvider’ reader.
14:45:23.286 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Toggle_6 (Type=SwitchItem, State=Uninitialized)’ with ‘HueGenericBindingProvider’ reader.
14:45:23.291 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Toggle_7 (Type=SwitchItem, State=Uninitialized)’ with ‘HueGenericBindingProvider’ reader.
14:45:23.294 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Toggle_8 (Type=SwitchItem, State=Uninitialized)’ with ‘HueGenericBindingProvider’ reader.
14:45:23.296 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Toggle_9 (Type=SwitchItem, State=Uninitialized)’ with ‘HueGenericBindingProvider’ reader.
14:45:23.298 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Color_1 (Type=ColorItem, State=Uninitialized)’ with ‘HueGenericBindingProvider’ reader.
14:45:23.301 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Color_2 (Type=ColorItem, State=Uninitialized)’ with ‘HueGenericBindingProvider’ reader.
14:45:23.303 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Color_3 (Type=ColorItem, State=Uninitialized)’ with ‘HueGenericBindingProvider’ reader.
14:45:23.305 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Color_4 (Type=ColorItem, State=Uninitialized)’ with ‘HueGenericBindingProvider’ reader.
14:45:23.308 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item ‘Color_5 (Type=ColorItem, State=Uninitialized)’ with ‘HueGenericBindingProvider’ reader.
14:45:23.310 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'Color_6
14:46:40.337 [DEBUG] [inding.hue.internal.HueBinding:97 ] - Start Hue data refresh
14:46:43.342 [WARN ] [.h.internal.hardware.HueBridge:147 ] - Failed to connect to Hue bridge: HTTP request timed out.
14:46:43.344 [WARN ] [inding.hue.internal.HueBinding:100 ] - Hue settings were null, maybe misconfigured bridge IP.
best
matt
