I have the following:
Switch vent_niveau_3 “Ventilation max” (vent) {ihc=“0x33c311”}
Is it possible to say that the switch when it is ON, it should do {ihc=“0x33c311”} and when OFF, it should do {ihc=“0x33c312”}?
Thanks,
John.
Thanks,
John.
That would depend on the binding. The IHC does seem to support that.
http://docs.openhab.org/addons/bindings/ihc1/readme.html
Hi John,
Maybe something like this?
Switch vent_niveau_3 "Ventilation max" <vent> {ihc="<0xHHHHHH,>[ON:0x33C311:70],>[OFF:0x33C312:70]"}
0xHHHHHH should be used for the IHC resource providing feedback state.
:70 is the pulse time in milliseconds.
Best regards Ole.
Yes it works. A big thanks !!!
How will this work with openhab 2 and the 2.0 binding? Is it configurable via paper UI? or doe I need to do this by edition the items files itself?
This three year old post was about IHC version 1 binding.
It’s no help at all for version 2 with Things and channels.
v2 binding docs
You’d be interested in the commandToReact
property of a switch channel.
The examples show how to use with a dimmer for two different commands - you set up two channels, each one reacting to just one command.
Then link both channels to the one Item.
You should be able to do all that in PaperUI
