Any idea how to use different sitemaps, that aren’t accessible to everybody?
I would like to have fe something like:
- Sitemap A > user A & B
- Sitemap B > user A
- Sitemap C > user B
Setup NGINX to provide & enforce user auth per-(sitemap-)URL ?
Auth done inside OH is in the works, too, but will probably take some more time to get released.
OK. Didn’t though on this one.
I’m only using NGINX to protect my setup from WAN side.
But indeed, maybe I could use NGINX to protect it from LAN as well.
Not sure if I can block all LAN access (since server is on internal network) directly to OpenHAB. Maybe an access list on the openhab webserver?
I’ll have a look…
configure the jetty to listen only on localhost
Back to this topic…
The question I have right now:
And of course, to complicate things: User A shouldn’t be able to see other sitemaps (like B, C…).
Before I start testing several things, I would like to have your opinions. I’m thinking fe of following possibilities:
OH Authentication
Don’t know if the auth inside OH has been developed some more?
Is this maybe possible through the Cloud Connector?
NGINX
I’m thinking of creating different nginx profiles.
Different OH servers/installations
Maybe different servers (virtuals) that have their own sitemap/habpanel?
But how can I let them talk to each-other (bindings KNX, zwave…)? Maybe through mqtt?
Others?
Thanks for you input!!!
Not that I’ve heard of.
