on sitemap, i’m looking for a 5 value switch like: #sitemap:
Switch item=DSS_UG_BuroSzene mappings=[0=“off”, 5=“Szene1”, 17=“Sezene2”, 18=“S3”, 19=“s4”]
OH tail log fail:
2017-12-22 15:50:28.455 [WARN ] [rest.core.internal.item.ItemResource] - Received HTTP POST request at 'items/DSS_UG_BuroSzene' with an invalid status value '17'.
Did you have the existing scenes discovered?
If not, go to inbox, do a new search on digitalSTROM Binding and all scenes will be discovered.
The just create a Switch Item you want to activate/deactivate.
If you want a multi selection, create a dummy Selection item with the different scenes to call. You can trigger a rule with the state of that dummy to controll your scenes.
Yes. I was not searching for the scene in the paperUI, rather looking for manual configuration. I Do have 100+ DS devices in my building: once starting the scan I will got crowded and maintenace became (at least with OH 1) very difficult…
Is there a path with manual configuration via binding .things?
I am not shure, as I don‘t use scenes or manual config.
To not flood your inbox, you could setup a second instance of openHAB on a different machine and let this one scan for the scenes.
You can check then how the channels for scenes look like and try to get the right syntax for manual config.
I will try to find some time to do the same, but can not make promises when this will happen.
