Issue of the topic: Dimensions were not displayed correct
All, I’m new to openHAB and installed the system some days ago and in process to setup the platform. Now I face an issue with dimensions. The binding with my Homatic Wall Thermostat with switching output gives back two values, set temp and actual temp. Set temp was recognized with “number:temperature” and actual with “number:dimensionless”. This leads that the actual temp is displayed incorrect without °C, just as a string. When I change the dimension on the channel portal at Paper UI to temperature, the change is not translated correctly and the display shows “-NaN”.
I wonder where do I need to change the config to apply the dimension the right way ?
That looks like an issue with the binding. I think you’d have to work around it by using it as Dimensionless Item and just displaying °C yourself in the Item’s label format [] part.
I fear it might break if you get a negative temperature or over 100, but I don’t suppose that’s likely here.
thanks, got that fixed but the problem stays the same. I tried to change the type in the DB but after a reboot it got overwritten from the binding I guess. Is there another location where I can change decimals or units e.g. C to F ?
So this seems to be a Paper UI issue only that no decimals / only integer values from HMIP-BWTH Temperature connected to Openhab via RaspberryMatic were shown.
I started logging values with influxdb and there are also decimals showing up for temperature
