I´ve set up openhab2 with Homematic devices. I added a dimmer item to remotely set the temperature of my heater. Unfortunately it does not work the way I wanted, actually it does not work at all.
In my openhab events.log I saw this:
2018-02-16 18:09:19.997 [ome.event.ItemCommandEvent] - Item 'HzSetTempBad' received command 42
2018-02-16 18:09:20.011 [vent.ItemStateChangedEvent] - HzSetTempBad changed from 0 to 42
2018-02-16 18:09:23.277 [vent.ItemStateChangedEvent] - HzSetTempBad changed from 42 to 41
2018-02-16 18:09:23.299 [vent.ItemStateChangedEvent] - HzTempBad changed from 25.30 to 25.40
So the dimmer sets a percentage value, but the heater obviously is working with °C values. I thought I could get the dimmer and the heat talk to each other using a rule which converts my percentage values into °C values.
Do you think taht would work? If so, could you help me to set up the rule, e.g. if you have an example or sth.!?
mmh, cool, I didn´t know it works this way, thanks for that!
But now my problem is I need this setpoint in my home.items. How could I implement it there? My sitemap looks like this, there are only my rooms grouped.
sitemap home label="Homecontrol"
Frame {
Group item=gFF label="Wohnung" icon="firstfloor"
Frame {
Group item=gBM label="Keller" icon="cellar"
Frame {
Group item=gAL label="Alarmanlage" icon="shield"
Group item=gVac {
Switch item=actionControl mappings=[vacuum="Vacuum", pause="Pause",spot="Spot", dock="Dock"]
Switch item=actionFan mappings=[38="Silent", 60="Normal", 77="Power",90="Full", -1="Custom"]
Default item=statusBat
Default item=statusArea
Default item=statusTime
Group item=gVacStat
Group item=gVacCons
Group item=gVacDND
Group item=gVacHist
Group item=gVacNetwork
/* Group item=TvWz {
Switch item=TvCommand mappings=[power="Aus", mute="Stumm"]
Default item=TvDimmer
/* Frame label="Date" {
Text item=Date
Frame label="Charts" icon="line"{
Webview item=ChartKz url="http://192.168.1.50:8080/static/Charts.html" height=7
Setpoint item=HzTargetTempBad minValue=4.5 maxValue=30.5 step=1.0
I actually want this setpoint item in my Bath group which is grouped in the gFF “Wohnung” group…
