Dimmer rule between scene light [SOLVED]
Hi everybody,
I’m stuck with a rule.
I use openhabian 2.5.3.1
with ikea tradfri binding.
to control my lights i use multiple rules scenes schemas: diner scene, evening scene and so on, such as:
rule "Ambiance soir"
    Item Ambiance_du_Soir received command ON
        Niche_Droite.sendCommand(30)
        Niche_Gauche.sendCommand(30)
        Niche_Milieu.sendCommand(60)
        Lumieres_TV.sendCommand(60)
        Plafond_Entree_2.sendCommand(0)
        Plafond_Entree_3.sendCommand(40)
        Plafond_Entree_4.sendCommand(0)
        Plafond_Entree_1.sendCommand(40)
        Plafond_Salle_A_Manger_1.sendCommand(30)
        Plafond_Salle_A_Manger_2.sendCommand(40)
        Plafond_Salle_A_Manger_3.sendCommand(30)
        ArcheDroite.sendCommand(20)
        ArcheGauche.sendCommand(20)
        ArcheMilieu.sendCommand(0)
        Lumieres_Cuisine.sendCommand(80)
        Lampe_Ambiance_Entree.sendCommand(50)
        Lampe_Ambiance_Entree_ColorTemperature.sendCommand(40)
        Lustre_1.sendCommand(15)
        LustreColorTemperature.sendCommand(0)
        LustreColor.sendCommand("39,85,84")
        Lumieres.postUpdate(ON)
        Ambiance_Apero.postUpdate(OFF)
        Ambiance_Diner.postUpdate(OFF)
        Ambiance_Matin.postUpdate(OFF)
        Ambiance_Film_Tele.postUpdate(OFF)
        Ambiance_Tele.postUpdate(OFF)
        Ambiance_Pleine_lumiere.postUpdate(OFF)
        Ambiance_du_Soir.postUpdate(ON)
        Ambiance_cosy.postUpdate(OFF)
        Ambiance_VP.postUpdate(OFF)
        Ambiance_feutree.postUpdate(OFF)
        Ambiance_pluie.postUpdate(OFF)
        //Bureau.postUpdate(OFF)
logInfo("Ambiance", "Ambiance soir")
rule "Ambiance_Diner"
    Item Ambiance_Diner received command ON
        Niche_Droite.sendCommand(50)
        Niche_Gauche.sendCommand(50)
        Niche_Milieu.sendCommand(50)
        Lumieres_TV.sendCommand(40)
        Plafond_Entree_2.sendCommand(60)
        Plafond_Entree_3.sendCommand(60)
        Plafond_Entree_1.sendCommand(0)
        Plafond_Salle_A_Manger_1.sendCommand(100)
        Plafond_Salle_A_Manger_2.sendCommand(100)
        Plafond_Salle_A_Manger_3.sendCommand(100)
        ArcheDroite.sendCommand(80)
        ArcheGauche.sendCommand(80)
        ArcheMilieu.sendCommand(50)
        Lumieres_Cuisine.sendCommand(100)
        Lampe_Ambiance_Entree.sendCommand(80)
        Lampe_Ambiance_Entree_ColorTemperature.sendCommand(20)
        Lustre_1.sendCommand(80)
        LustreColorTemperature.sendCommand(90)
        Ambiance_Diner.postUpdate(ON)
        Ambiance_du_Soir.postUpdate(OFF)
logInfo("Ambiance", "Ambiance diner")
any of them are triggered trought prescence detection or time cron or timer, i know that i can simplify my rules (using design patern) but this method is the one that i can understand.
i want to integrate a slow dimmer between each scene for example slowly dimme light from evening scene to diner scene, to be more precise, dimme light from 30% to 60% during 45 min for example.
i’m testing this kind of rule:
var Timer Timer0 = null
rule "morning alarm"
        Time cron "0 32 10 1/1 * ? *"
        logInfo("morningAlarm", "Wakeup Started")
        if(G_Presence.state == ON && Timer0 === null) {
            Timer0 = createTimer(now.plusSeconds(1)) [ |
                if ((Niche_Milieu.state as Number) < 100) {
                    Niche_Milieu.sendCommand((Niche_Milieu.state as Number) + 10)       10
                    Timer0.reschedule(now.plusMinutes(1))
                else
                    Timer0 = null
        else if(Niche_Milieu.state==ON) {
            Niche_Milieu.sendCommand(OFF)
            Timer0.cancel
            Timer0 = null
            logInfo("morningAlarm", "Wakeup Ended")
i found a rule example that can correspond to my schema, but i’m stuck with departure value to a specific one.
Can you please put me on the right direction
Not sure what you mean by this?
i mean by using this method :
                else
                    Timer0 = null
            Timer0.cancel
            Timer0 = null
i start from the 0% level of the light (tunr off) to 100% level, i want to start from 60% to 90%
Just add a command to send the value of 60 at the start of the rule and change the number values in the rule as needed.
ok for the departure value but how to stop it to a specific %level not 100%
Change this to 90
So, following your suggestions, i’ ve made my rule, looking like this
rule "evening dimmer"
        Time cron "0 51 22 1/1 * ? *"
        logInfo("Dimmer.rules", "Evening dimmer")
            Timer0 = createTimer(now.plusSeconds(1)) [ |                                // Create a Timer
                if (((Niche_Gauche.state as Number) < 50) &&
                    ((Niche_Milieu.state as Number) > 50) &&
                    ((Niche_Droite.state as Number) < 50) &&
                    ((Lumieres_TV.state as Number) > 40) &&
                    ((Plafond_Entree_2.state as Number) < 60) &&
                    ((Plafond_Entree_3.state as Number) < 60) &&
                    ((Plafond_Entree_1.state as Number) > 0) &&
                    ((Plafond_Salle_A_Manger_1.state as Number) < 100) &&
                    ((Plafond_Salle_A_Manger_2.state as Number) < 100) &&
                    ((Plafond_Salle_A_Manger_3.state as Number) < 100) &&
                    ((ArcheDroite.state as Number) < 80) &&
                    ((ArcheGauche.state as Number) < 80) &&
                    ((ArcheMilieu.state as Number) < 50) &&
                    ((Lumieres_Cuisine.state as Number) < 100) &&
                    ((Lampe_Ambiance_Entree.state as Number) < 80) &&
                    ((Lampe_Ambiance_Entree_ColorTemperature.state as Number) > 20) &&
                    ((Lustre_1.state as Number) < 80) &&
                    ((LustreColorTemperature.state as Number) < 90) &&
                    Ambiance_du_Soir.state == ON ) {                             // already reached highest Level?
                    Niche_Gauche.sendCommand((Niche_Gauche.state as Number) + 5)       // Increase Level by 10
                    Niche_Milieu.sendCommand((Niche_Milieu.state as Number) + 5)
                    Niche_Droite.sendCommand((Niche_Droite.state as Number) + 5)
                    Lumieres_TV.sendCommand((Lumieres_TV.state as Number) - 5)
                    Plafond_Entree_2.sendCommand((Plafond_Entree_2.state as Number) + 5)
                    Plafond_Entree_3.sendCommand((Plafond_Entree_3.state as Number) + 1)
                    Plafond_Entree_1.sendCommand((Plafond_Entree_1.state as Number) - 5)
                    Plafond_Salle_A_Manger_1.sendCommand((Plafond_Salle_A_Manger_1.state as Number) + 5)
                    Plafond_Salle_A_Manger_2.sendCommand((Plafond_Salle_A_Manger_2.state as Number) + 2)
                    Plafond_Salle_A_Manger_3.sendCommand((Plafond_Salle_A_Manger_3.state as Number) + 5)
                    ArcheDroite.sendCommand((ArcheDroite.state as Number) + 5)
                    ArcheGauche.sendCommand((ArcheGauche.state as Number) + 5)
                    ArcheMilieu.sendCommand((ArcheMilieu.state as Number) + 1)
                    Lumieres_Cuisine.sendCommand((Lumieres_Cuisine.state as Number) + 1)
                    Lampe_Ambiance_Entree.sendCommand((Lampe_Ambiance_Entree.state as Number) + 1)
                    Lampe_Ambiance_Entree_ColorTemperature.sendCommand((Lampe_Ambiance_Entree_ColorTemperature.state as Number) + 5)
                    Lustre_1.sendCommand((Lustre_1.state as Number) + 5)
                    LustreColorTemperature.sendCommand((LustreColorTemperature.state as Number) + 5)
                    Timer0.reschedule(now.plusMinutes(1))                               // Reschedule Timer
                else
                    Timer0 = null                                                       // reinitialize Timer
        /*else if(Niche_Milieu.state==ON) {
            Niche_Milieu.sendCommand(OFF)                                               // Switch off
            Timer0.cancel                                                               // Cancel Timer if running
The switch between the two scenes works but stop as soon as one of the light value is reached
in that case the first reached value is the lumieres TV (from 60% to 40% ) prevent other to continue their way to reached their own value
So if I got it right you want to fade between two complex scenes. You will need do fade per item individually, but of course you can do it in one timer. you will need to save some information for correct calculation, and this is per item. So maybe it would be wise to do a persistence for all of these items (everyChange strategy) and only save the timestamp when fading starts. Now it’s possible to get the start value via persistence (Item.historicState(timestamp).state). The timer could be started once per Second, and if the fade should last a minute, all you have to do is to calculate the new level by startlevel + (endlevel-startlevel)/60 * fade step, where fade step is the number of Seconds past start of fade. e.g.
var DateTime dtFadeStart = null
var Timer tFade = null
var Number nCount = 0
rule "fade to scene 1"
    // some trigger
    if(dtFadeStart === null && tFade === null) {
        nCount = 0
        dtFadeStart = now
        tFade = createTimer(now.plusMillis(10), [ |
            nCount = nCount + 1
            if(nCount < 60) {
            // new Level for Light shall be 55
                Light.sendCommand((Light.historicState(dtFadeStart).state as Number) + (55 - (Light.historicState(dtFadeStart).state as Number)) / 60 * nCount)
            // new Level for Light2 shall be 25
                Light2.sendCommand((Light2.historicState(dtFadeStart).state as Number) + (25 - (Light2.historicState(dtFadeStart).state as Number)) / 60 * nCount)
                tFade.reschedule(now.plusSeconds(1))
            } else {
                dtFadeStart = null
                tFade = null
I did not test this, so the code may have issues :slight_smile: but I’m sure you get the idea.
@Udo_Hartmann
thanks you, for all these explainations.
So , as you advise, i put all my items in the rrd4j persistence with the everychange strategie.
i tried to manipulate your rule with my own item
    Item Boutton received command ON
        nCount = 0
        dtFadeStart = now
            nCount = nCount + 1
            if(nCount < 60) {
                Niche_Milieu.sendCommand((Niche_Milieu.historicState(dtFadeStart).state as Number) + (100 - (Niche_Milieu.historicState(dtFadeStart).state as Number)) / 60 * nCount)
                Niche_Gauche.sendCommand((Niche_Gauche.historicState(dtFadeStart).state as Number) + (25 - (Niche_Gauche.historicState(dtFadeStart).state as Number)) / 60 * nCount)
            } else {
                dtFadeStart = null
                tFade = null
        logInfo("Transitions.rules", "fade to scene 1")
, but nothing happens, and this error appears
Rule 'fade to scene 1': The name 'dtFadeStart' cannot be resolved to an item or type; line 7, column 8, length 11
, i’m not confortable with var value yet, and i think i missed something in your formula.
[quote="yippicai, post:9, topic:96878"]
[/quote]
Just make sure you have all the var’s listed at the top of your rule as Udo_Hartmann posted and the rule should work.
My bad i forgot var value, thx for your pointing.
i’ve resolved that and still error
2020-04-19 16:46:51.170 [INFO ] [thome.model.script.Transitions.rules] - fade to scene 1
2020-04-19 16:46:51.359 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'transition.rules'
2020-04-19 16:47:01.147 [ERROR] [org.quartz.core.JobRunShell         ] - Job DEFAULT.Timer 4 2020-04-19T16:47:01.145+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
  <null>.nCount = <XBinaryOperationImplCustom>
  org.eclipse.xtext.xbase.impl.XIfExpressionImpl@10c21d5 (conditionalExpression: false)
} ] threw an unhandled Exception:
	at org.eclipse.smarthome.model.script.engine.ScriptError.<init>(ScriptError.java:65) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:140) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:991) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:954) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:235) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:215) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1205) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1135) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1081) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:237) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1301) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:458) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:239) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:201) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
	at com.sun.proxy.$Proxy333.apply(Unknown Source) ~[?:?]
	at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:48) ~[?:?]
	at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [bundleFile:?]
	at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [bundleFile:?]
2020-04-19 16:47:01.178 [ERROR] [org.quartz.core.ErrorLogger         ] - Job (DEFAULT.Timer 4 2020-04-19T16:47:01.145+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
	at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [bundleFile:?]
Caused by: java.lang.NullPointerException
	at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
	... 1 more
Try changing this
 nCount = nCount + 1
to
nCount +=1
still error
        nCount = 0
        dtFadeStart = now
            nCount +=1
            if(nCount < 60) {
                Niche_Milieu.sendCommand((Niche_Milieu.historicState(dtFadeStart).state as Number) + (55 - (Niche_Milieu.historicState(dtFadeStart).state as Number)) / 60 * nCount)
            } else {
                dtFadeStart = null
                tFade = null
Hmm. Is rrd4j default persistence? If not, you have to change historicState slightly:
                Niche_Milieu.sendCommand((Niche_Milieu.historicState(dtFadeStart,"rrd4j").state as Number) + (55 - (Niche_Milieu.historicState(dtFadeStart,"rrd4j").state as Number)) / 60 * nCount)
Of course this applies for all historicState calls.
Maybe it’s better to use a var, although it’s more lines of code…
var oldVal = 0
var newVal = 0
oldVal = Niche_Milieu.historicState(dtFadeStart,"rrd4j").state
newVal = 55
if(oldVal !== null) Niche_Milieu.sendCommand((oldVal as Number) + (newVal - (oldVal as Number))/60*nCount)
oldVal = (Niche_Gauche.historicState(dtFadeStart,"rrd4j").state
newVal = 25
if(oldVal !== null) Niche_Gauche.sendCommand((oldVal as Number) + (newVal - (oldVal as Number))/60*nCount)
I’m not sure though, if this will work as intended :slight_smile:
no it doesn’t work at all :expressionless:
hi guys thanks for your time both of you…
as i told you i’m not confiortable with var, but anyway i love to learn, and i want the machine do what i want.
So i break down the rule step by step and it seems that the historic state calls won’t work with RRD4j persistence,
https://community.openhab.org/t/historicstate-not-working-with-rrd4j/40254/11
and it’s confirm by the rule i made to test it by my own
var DateTime test_time
rule "Test"
	Item Boutton changed to ON
	time_play_started = now
	logInfo("test"," HistoricalState 1: " + Niche_Milieu.historicState(now.minusDays(1)))
	logInfo("test"," HistoricalState 2: " + Niche_Gauche.historicState(now.minusDays(1)))
	logInfo("test"," HistoricalState 3: " + Niche_Droite.historicState(now.minusDays(1)))
with either .state or not
wich return this error
2020-04-22 01:34:12.840 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Test': cannot invoke method public abstract org.eclipse.smarthome.core.types.State org.eclipse.smarthome.core.persistence.HistoricItem.getState() on null
so i checked my persistence service with the rest api
  "name": "Niche_Milieu",
  "datapoints": "44",
  "data": [
      "time": 1587430740000,
      "state": "0"
      "time": 1587452220000,
      "state": "5"
      "time": 1587477600000,
      "state": "0"
      "time": 1587489780000,
      "state": "60"
      "time": 1587489840000,
      "state": "60"
it’s seems to store some data
here is my persistence config files, for eye only
Strategies {
    // for rrd charts, we need a cron strategy
    everyMinute : "0 * * * * ?"
    everyhour : "0 0 * * * ?"
    everyDay :"0 0 0 * * ?"
    default = everyChange
Items {
    // persist items on every change and every minute
    StationMeteoTemperature : strategy = everyMinute
    StationMeteohumidity : strategy = everyMinute
    LocalWeatherAndForecastCurrentHumidity : strategy = everyMinute
    LocalWeatherAndForecastCurrentTemperature : strategy = everyMinute
    win10_start : strategy = everyChange
    win10_shutdown : strategy = everyChange
    PC_ON_OFF : strategy = everyChange
    Bureau : strategy = everyChange
    CurrentActivity : strategy = everyChange
    Lumieres_niche : strategy = everyChange
    Lumieres_TV : strategy = everyChange
    Lumieres_Arche : strategy = everyChange
    Lumieres_Plafond_entree : strategy = everyChange
    Lumieres_PLafond_Salle_a_manger : strategy = everyChange
    Lumieres_Ambiance : strategy = everyChange
    Lustre_1 : strategy = everyChange
    LustreColorTemperature : strategy = everyChange
    LustreColor : strategy = everyChange
    ArcheDroite : strategy = everyChange
    ArcheGauche : strategy = everyChange
    ArcheMilieu : strategy = everyChange
    Plafond_Salle_A_Manger_1 : strategy = everyChange
    Plafond_Salle_A_Manger_2 : strategy = everyChange
    Plafond_Salle_A_Manger_3 : strategy = everyChange
    Lampe_Ambiance_Entree : strategy = everyChange
    Lampe_Ambiance_Entree_ColorTemperature : strategy = everyChange
    Plafond_Entree_1 : strategy = everyChange
    Plafond_Entree_2 : strategy = everyChange
    Plafond_Entree_3 : strategy = everyChange
    Plafond_Entree_4 : strategy = everyChange
    Niche_Milieu : strategy = everyChange
    Niche_Droite : strategy = everyChange
    Niche_Gauche : strategy = everyChange
    Meuble_Tv_Droite : strategy = everyChange
    Meuble_Tv_Gauche : strategy = everyChange
    Cuisine1 : strategy = everyChange
    Cuisine2 : strategy = everyChange
    Cuisine3 : strategy = everyChange
    Cuisine4 : strategy = everyChange
still stuck with this ******rules
In the rule use the persistence as per the doc’s and not just as logInfo.
But maybe your calls are not going to rrd4j at all.
accesses your default persistence service. Have you set one? What is it?
Try
Niche_Milieu.historicState(now.minusDays(1), "rrd4j")
Note that will return a HistoricState object, which is not an Item or a state. The objects most interesting properties are the .state and .timestamp
This is a handy trick for looking at an object in a logInfo(), using curly braces -
logInfo("test"," HistoricalState 1: {}",  Niche_Milieu.historicState(now.minusDays(1), "rrd4j"))
@Udo_Hartmann.
here is the solution thanks to the rules you edited :
var Number nCount = 12
        nCount = 0
        tFade = createTimer(now.plusMillis(10000), [ |
            nCount = nCount + 1
            if(nCount <= 12) {
                dtFadeStart = now.minusMinutes(1)
            // new Level for Niche_Milieu shall be 100
                Niche_Milieu.sendCommand(Niche_Milieu.historicState(dtFadeStart,"rrd4j").state as Number  + (40 - (Niche_Milieu.historicState(dtFadeStart,"rrd4j").state as Number)) / 12 * nCount)
            // new Level for Niche_Gauche shall be 30
                Niche_Gauche.sendCommand(Niche_Gauche.historicState(dtFadeStart,"rrd4j").state as Number  + (40 - (Niche_Gauche.historicState(dtFadeStart,"rrd4j").state as Number)) / 12 * nCount)
                tFade.reschedule(now.plusSeconds(60))
            else {
                dtFadeStart = null
                tFade = null
i adjusted it ,
i reinstalled rrd4j persistence, wich caused some problem and everything works like a charm now
