I created some floorplans with my openhab 3.0 on raspberry.
I can control „normal“ lights with toggle command off/on.
But how do I show a dimmer slider at the floorplan? I can’t find an action for this.
I can send command options with preconfigured values, but this is not a great solution for a dimmer where you can adjust from 0-100.
The same is for roller shutters. I can send command options with values. But I would like to have the buttons for up, down and stop like on the devices tab at the dashboard.
Thank you!
Best regards
Dirk
