DimmerItem Type error?
Hi Guys,
I see an odd error on boot up with the below. I do have a proxy defined as this name, but it’s a switch, not a dimmer.
I cant seem to find where this exists - even in rules. Is there a trick to locating or help determine why this occurs?
21:31:23.861 [WARN ] [core.common.registry.AbstractRegistry] - DimmerItem with key 'PS4Scene_Alexa' already exists from provider GenericItemProvider! Failed to add a second with the same UID from provider GenericItemProvider!
Rule:
// Yamaha PS4 Scene via Alexa Dummy Item
rule "PS4 Scene Alexa"
                Item PS4Scene_Alexa received command
            switch (receivedCommand)
                        case ON:           sendCommand(Zone_1_Scene, 'Scene 2')
                        case OFF:          sendCommand(Main_Zone_Power, 'OFF')
Items:
Switch PS4Scene_Alexa                              "Proxy for Playing PS4 Via Alexa"                                             [ "Switchable" ]
Switch Spotify_Alexa                               "Proxy for Playing Spotify via Alexa"                                         [ "Switchable" ]
Switch FibaroEye1Motion_Armed                      "Proxy to Disable/Enable Motion Sensor during Movies"
Switch Motion_PartyMode                            "Proxy to Disable/Enable Motion Sensing for All Motion Sensors"               [ "Switchable" ]
Switch Scene_Watch_Vero                            "Proxy for Watching a Vero Movie via Alexa"                                   [ "Switchable" ]
Switch Scene_Leaving_House                         "Proxy for Occupants leaving the House via Alexa" [ "Switchable" ]
Switch Night_time                                  "Night"
String MENU_page
Switch HeaterTimer                                 "Proxy for The Heater"
Switch Vero                                        "Proxy for Vero"
/* This switch will be used in the Entertainment Rule to change Input to FTA */
Switch TVProxyFTA                                  "FTA Switch"
Switch TVStatus                                                             { channel="network:pingdevice:1bad045e:online" }
/* Perform OpenHab2 Operations */
Switch restartoh2                                  "Restarts OpenHab2"
Switch restartserver                               "Restarts UCS-E OH2 Server"
Switch backupserver                                "Backup Server"
Switch restartkodi                                 "Restarts Kodi"
/* Proxies for Motion Detection Around the House */
Switch Motion_Garage                               "Detects Motion in the Garage"
Switch Motion_Carport                              "Detects Motion in the Carport"
/* Proxy for Turning on & off Blue Iris Motion Recording */
Switch BlueIris_Motion_Arm                         "Turns on/off Blue Iris Motion Recording"
Go through all you items files to check you have got the item twice
Also go through you items in paperUI
Roger!
Also, this is preferable.
case ON:           Zone_1_Scene.sendCommand("Scene 2")
case OFF:          Main_Zone_Power.sendCommand(OFF)
Assuming Main_Zone_Power is a Switch item.
See here for more details.
Thanks Mark, my items are dimmer types.
This works fine for the aircon switching it off, but fails when switching it on. Its very odd!
// Aircon  On/Off via Alexa Dummy Item
rule "Aircon Alexa"
                Item Aircon_Alexa received command
                        case ON:           sendCommand(Aircon, "AirconOn")
                        case OFF:          sendCommand(Aircon, "AirconOff")
Using the console with this command switches it on just fine… Any thoughts?
openhab> smarthome:send Aircon AirconOn
Command has been sent successfully.
openhab>
How is the Aircon Item defined? Switch or String?
Its a string because im using the broadlink binding with an rm mini
well.. your rule should work in this case.
you can try to use the method instead of the action:
rule "Aircon Alexa"
			case ON:	Aircon.sendCommand(AirconOn)
			case OFF:	Aircon.sendCommand(AirconOff)
Ps: what solution did I provide in the previous post? :slight_smile:
Same result :frowning: Switches off using this rule, wont switch on.
well… then you have an issue with the binding and/or the device itself
does it support switching on?
the rule is fine
Yes, i use the same rule using the same brinding for the TV, it switches on just fine.
And as mentioned I can send the command via the Console just fine.
So it has to be the rule?
inject logInfos to see if the case ON is triggered
Not sure I did it right..
17:15:09.326 [INFO ] [smarthome.event.ItemCommandEvent     ] - Item 'Aircon_Alexa' received command 100
17:15:09.329 [INFO ] [smarthome.event.ItemStateChangedEvent] - Aircon_Alexa changed from 0 to 100
17:15:09.779 [INFO ] [eclipse.smarthome.model.script.Aircon] - Case ON
rule "Aircon Alexa"
                        case ON:           Aircon.sendCommand("AirconOn")
                        case OFF:          Aircon.sendCommand("AirconOff")
logInfo("Aircon", "Case ON")
within the case:
rule "Aircon Alexa"
			case ON:	{
						logInfo("Aircon_Alexa", "Got ON, sending AirconOn")
			case OFF:	{
						logInfo("Aircon_Alexa", "Got OFF, sending AirconOff")
Of course the rule will NOT work…
You are receiving 100 and your rule is looking for ON…
Posting a rule without the relevant items is like shooting yourself (and others) on the leg :slight_smile:
But this is using Alexa, its a dimmer item, apparently it needs to be.
Dimmer Aircon_Alexa "Aircon" [ "Switchable" ] // Dummy Item for Alexa as it doesnt understand Strings
It can be whatever
If your rule is looking for ON/OFF and your Item is getting 100/0 instead… guess what will happen…
change the Aircon_Alexa Item to a Switch
Thank you Sir :smiley:
I was told I had to use Dimmer items, but Switches are working, Thanks Angelos. You’re a guru :smiley:
