I am having a weird issue with my Tasmota RGBWW bulbs that flicker when the dimmers are being adjusted in HomeKit. It looks like they briefly switch to 100% while raising or lowering the value on a slider.
I am not sure if this is a HomeKit, openHAB, or Tasmota issue. I don’t see the flashing when using sliders in OH2 (Sitemaps and PaperUI->Control), but they are not a live adjust like in HomeKit (the bulb does not change until you let go of the slider).
Has anyone else run into this problem and have a solution?
Here is a sample of my configuration…
Things:
Bridge mqtt:broker:myBroker [ host="192.168.xxx.xxx", secure=false, username="user", password="pass" ] {
Thing mqtt:topic:diningRoomLight "Dining Room Light"
{ Channels:
Type switch : diningRoomLightPower "Light" [ stateTopic="stat/diningRoomLight/POWER", commandTopic="cmnd/diningRoomLight/POWER" ]
Type dimmer : diningRoomLightBrightness "Brightness" [ stateTopic="stat/diningRoomLight/DIMMER", commandTopic="cmnd/diningRoomLight/DIMMER" ]
Type dimmer : diningRoomLightWarmth "Warmth" [ stateTopic="stat/diningRoomLight/CT", commandTopic="cmnd/diningRoomLight/CT", min=153, max=500, step=10 ]
Type colorHSB : diningRoomLightColor "Color" [ stateTopic="stat/diningRoomLight/HSBColor", commandTopic="cmnd/diningRoomLight/HSBColor" ]
Items:
Switch diningRoomLightPower "Light" ["Lighting"] { channel="mqtt:topic:diningRoomLight:diningRoomLightPower" }
Dimmer diningRoomLightBrightness "Brightness" ["Lighting"] { channel="mqtt:topic:diningRoomLight:diningRoomLightBrightness" }
Dimmer diningRoomLightWarmth "Warmth" ["Lighting"] { channel="mqtt:topic:diningRoomLight:diningRoomLightWarmth" }
Color diningRoomLightColor "Color" ["Lighting"] { channel="mqtt:topic:diningRoomLight:diningRoomLightColor" }
Sitemap:
sitemap lightTest label="Lighting Slider Test" {
Frame label="Dining Room Light" {
Switch item=diningRoomLightPower label="Power" icon="switch"
Slider item=diningRoomLightBrightness label="Brightness" icon="slider" sendFrequency=0 minValue=1 maxValue=100 step=1
Slider item=diningRoomLightWarmth label="Warmth" icon="slider" sendFrequency=0 minValue=1 maxValue=100 step=1
Colorpicker item=diningRoomLightColor label="Color" icon="colorpicker" sendFrequency=0
