is it possible to enable/disable a bundle (or binding) from BasicUI using a simple control switch?
I know that it is possible to call the console via SSH and then issue >> bundle:stop XXX
And I know that it is possible in general to issue a shell command via the Exec binding.
But I haven’t found a way, yet, to issue a console command from UI…
Background:
I use the max! binding which is only stable when the connection to the max cube is exclusive. However, to access the max cube with other applications, one must deactivate the bundle in openhab before, which works fine via the console. But I haven’t found a way to get it working directly out of the UI…
I am running Openhab2.0 on a Raspi (openhabian) and control it with BasicUI from a smartphone…works very well so far.
Any help would be highly appreciated.
Greetings,
Alex
