Disable internet connection of specific echo device on fritz box via script
  1. Create an access profile for the echo device
    1.1 FRITZ!Box Web UI → Internet → Filter → Access Profiles → New Access Profile
    FRITZ!Box 7590 Help - Access Profiles
  2. Map the access profile to the echo device
    2.1 FRITZ!Box Web UI → Internet → Filter → Parental Control
    FRITZ!Box 7590 Help - Parental Controls
  3. Get the access profile id
    3.1 Open the web developer tools - network monitor on Firefox (F12 → Network)
    Network Monitor — Firefox Source Docs documentation
    3.2 Edit the access profile created in step 1
    3.4 Select the first POST request with the file data.lua
    3.5 Select parameters of the request
    3.6 Copy the value of the „edit“ parameter (example filtprof1234)
  4. Run the attached script with the following parameters
    enable internet connection of the echo device → fritzboxprofile.sh [ip] [password] [profileid] unlimited
    disable internet connection of the echo device → fritzboxprofile.sh [ip] [password] [profileid] never
Example for openHAB
Items
Group:Switch:OR(ON,OFF) echoanaus "Alle Echos" ["Switchable"]
Switch echoesszimmeranaus "Echo Esszimmer" (echoanaus) ["Switchable"]
Rules
rule "echoesszimmeranaus"
	Item echoesszimmeranaus changed
	createTimer(now) [|
		if (echoesszimmeranaus.state == OFF) {
			executeCommandLine("/etc/openhab2/scripts/fritzboxprofile.sh 192.168.178.1 fritzboxpasswort filtprof1234 never", 5000)
		} else {
			executeCommandLine("/etc/openhab2/scripts/fritzboxprofile.sh 192.168.178.1 fritzboxpasswort filtprof1234 unlimited", 5000)
  1. Search for the devices in the alexa app
  2. Say „Alexa, schalte Echo Esszimmer aus“ or „Alexa, schalte Alle Echos aus“
  3. Add the item to the sitemap to enable an echo device
Script
#!/bin/sh
challenge=$(curl -s "http://$1/login_sid.lua?username=" | grep -Po '(?<=<Challenge>).*?(?=</Challenge>)')
md5=$(echo -n ${challenge}"-"$2 | iconv -f ISO8859-1 -t UTF-16LE | md5sum -b | awk '{print substr($0,1,32)}')
response="${challenge}-${md5}"
sid=$(curl -i -s -k -d "response=${response}&username=" "http://$1" | grep -Po -m 1 '(?<=sid=)[a-f\d]+' | tail -1)
curl -d "sid=${sid}&edit=$3&time=$4&budget=unlimited&apply=&page=kids_profileedit" "http://$1/data.lua" >/dev/null 2>&1
Sources
  1. Informationen aus dem Webinterface einer Fritz!Box via Shellscript auslesen - Administrator
  2. FRITZ!Box: WLAN-Toggle per Skript • Kuketz IT-Security Blog
Only tested with FRITZ!Box 7590
Tested on RaspberryPi
Can i use this for OH3?
what do I have to convert?
it still works like it is for OH3.
Br
Hi, in case anybody else wonders: with the latest 7.25 firmware there is a default username for the standard fritzbox admin user. Check it out in the fritzbox gui and add it behind ‘username=’ in the fritzbox.sh script. Took me few minutes to figure that one out…
Thanks for the solution!
I am still using this script and had to make some updates in recent FritzOS (7.39 in my case).
Previously, extracting the SID was done with this
I had to change it to that and it works again
grep -Po -m 1 '(?<=sid\":\")[a-f\d]+' | tail -1
Thanks, was wondering why it was no longer working :slight_smile:
In 7.57 it doesn’t seem to work any more. I get another Syntax and an empty sid:
...rnet":false,"pushmailEnabled":true,"sid":"0000000000000000"}; if (window.gNbc) { data.nbc...
Adding username didn’t help.
Does anyone have a working solution?
This looks like username/password combination is not correct.
I get this sid in case e.g. the username is empty but the correct password is used.
Finally i chose to integrate it in this project:
https://github.com/jhubig/FritzBoxShell
The guy there takes care for all tha basic stuff like authentication, it’s much easier like this for me.
