I have what I feel must be an easy questions. I am using a very simple rule to turn my espresso machine on in the early morning and off again after a few hours. I included the actual rule below for clarity. I would like to be able to turn off this rule at will with a switch in in the site map. With this if I do not want the machine to turn on the next morning or in near future the entire rule will be disabled.
Can a rule be referred to as a binding or some other method on a switch item? After thinking more on this I am pretty sure that the answer here will lie in a nested if/then or when/then but I am not coming up with too many examples of something that might work for the issue.
Any help is greatly appreciated!
rule "Coffee on 630am"
Time cron "00 30 06 * * ?"
sendCommand(plug5, ON)
rule "Coffee off 1130"
Time cron "00 30 11 * * ?"
sendCommand(plug5, OFF)
Thanks for the response! I know this is probably obvious but at least at first glance I cant figure out how to integrate this suggestion. I included my updated code with the other suggestions. I did notice that the timer did flip back to off and between the on and off times I was not able to set it to on. Is that what the unintialized item takes care of? Thanks all in advance.
if (coffeetimer.state == ON) {
