Platform information:
Hardware: Rasberry PI 4
OS: openHABian
Java Runtime Environment:  OpenJDK Java 8
openHAB version: 1.5
Issue of the topic: Discovery API REST
Hi!
I have read this
and I found API rest “discover” in the REST api.
but how to autorize device “discovered” and adding it in the sitemap?
                H102
                    November 29, 2019,  1:26pm
                  2
              You need to add the items (manually) to your sitemap file. See https://www.openhab.org/docs/configuration/sitemaps.html
              can i can new device but i can’t adding it to sitemap on rest api?
                H102
                    November 29, 2019,  1:32pm
                  4
Not that I am aware of, you need to manually create this file. I can post an example if needed. How many items do you have?
              3 items for now.
i 'm writing an app for controling openhub in remote only in rest (i can’t use openhab UI).
i need to adding discovered item in authorized list and see them in sensor list
i can do it with rest API?
thanks for help
                H102
                    November 29, 2019,  1:46pm
                  6
 luca-parlapiano:
You can’t use BasicUI, ClasicUI then why a sitemap?
              I seemed to understand that the list of items is the sitemap.
                H102
                    November 29, 2019,  1:50pm
                  8
              When you open a browser and enter http://your_servers_IP_address:8080/start/index what do you see?
              i see openhub select interface (basic - ecc)
                H102
                    November 29, 2019,  1:54pm
                  10
              So you see BasicUI as a selection. This will be empty until you create the sitemap file and add your items.
Currently, the sitemap is a file, not accessible directly from the REST API for editing.
                H102
                    November 29, 2019,  2:00pm
                  13
Thanks Bruce.
                H102
                    November 29, 2019,  2:04pm
                  14
              @luca-parlapiano  also in PaperUI > Configuration > Addons > User Interfaces you will need to install BasicUi or whatever UI you prefer. BTW, BasicUI is a good starting point.
              i can’t use UI only api rest.
but thanks for help
I have seen this api in rest page:http://demo.openhab.org:8080/doc/index.html#/
with this api i can create ad item
PUT /items/createOrUpdateItemhttp://demo.openhab.org:8080/doc/index.html#!/items/createOrUpdateItem )
widh this call i can add sensor?
                rlkoshak
                    November 29, 2019,  4:37pm
                  16
              Install the REST API docs add-on. The answer to all your questions are documented there.
              now i’m reading it, but i need some test.
Thanks at all for help !!
