I’m trying to get an IKEA Trådfri bulb to work with OpenHAB (running on a Raspberry Pi) using the Elelabs USB Zigbee dongle. The communication between the dongle and OpenHAB seems to be working (i.e. I don’t think this relates to serial port settings/access rights). It would initally switch between being “online” and “unknown” but “reset controller” plus restarting OpenHAB solved that and it hasn’t happened since (across multiple restarts). I’ve tried to scan for the bulb as described in the user guide (https://elelabs.com/wp-content/uploads/2019/02/EZBUSBA_UG_3_OpenHab.pdf). I’ve also tried to flash the dongle with v6 and v8 firmware as described here: https://github.com/Elelabs/elelabs-zigbee-ezsp-utility
The bulb is brand new one (I bought it specifically for this as that’s what’s used in the user guide, before that I also unsuccessfully tried a HUE light switch and bulb), i.e. it has never been associated with any home automation system (nor should there have been any other systems within reach as I did these tests at work where there are no other buildings nearby).
Settings for the “Ember EM35x Coordinator” thing (I think these are, apart from the serial settings, defaults):
Port: /dev/ttyUSB0
Flow Control: Hardware (CTS/RTS)
Baud Rate: 115200
Power Mode: Boost
Transmit Power: Normal
Child Aging Timeout: 1 Day
Network Size: Medium (25)
Channel: Channel 11
PAN ID: 18136
Extended PAN ID: B5801FD1402DEA44
Network Security Key: F6AC4B6B345ADF41776B4D228A6502F0
Link Security Key: 5A6967426565416C6C69616E63653039
Install Code:
Mesh Update Period: 1 Day
Trust Centre Join Mode: Allow only secure joining
Concentrator Type: Low RAM
I intended to attach the logs here but as a newly registered user I can’t. There was nothing in them that indicates to me that there is communication with the bulb but it could be me not knowing what it would look like. There are no lines in the log at the time I turn on the bulb which looks different from was logged before I started the scan, just a lot of lines like
ASH: TX EZSP queue size: 1
–> TX ASH frame: AshFrameData [frmNum=5, ackNum=6, reTx=false, data=95 00 01 18 00]
<-- RX ASH frame: AshFrameData [frmNum=6, ackNum=6, reTx=false, data=95 80 01 18 00 02]
ASH: Frame acked and removed AshFrameData [frmNum=5, ackNum=6, reTx=false, data=95 00 01 18 00]
–> TX ASH frame: AshFrameAck [ackNum=7, notRdy=false]
I later also tried it with “Allow all joins” (but didn’t save the logs as they seemed similar).
What am I supposed to see in the logs when it’s working? Have I missed something in the settings? One thing I note is that the log says PANID 65535 (i.e. -1 in 16 bits), not 18136 as in the settings.
