Using openhabien with oh 3 on a raspberry 4.
Works for the most fine.
I use a weather widget that i have modified. The only Thing that dosen’t work is to include a image item in oh-image. The weathercompany bindig return a weather icon as a image. In the channel i can see it.
That should be the correct configuration for the oh-image. The syntax on your expression appears to be correct although you can also simplify it to this:
So the only place the problem can be is with your props.itemPrefix2 value. Are you sure that your property is set correctly? I suggest you quickly add a test Label to the widget to make sure that the result of your expression actually equals 'Weather_Company_Forecast_ForecastDay0Day_IconImage`.
Thanks, for simplify and the label trick.
The prefix was correct, but in the widget editor the image not displayed.
I have opened a second tab on the browser and the image appear.
Sometimes the screenview of the widget view leaks…
