Display HABpanel on Chromecast in OH2?
Hello -
I’ve researched this a little and have found some hackish solutions that could work, but I was curious if anyone has found an elegant way to display a HABpanel page on the Chromecast?
have you? I’m now in pursuit of that solution. Thanks
I haven’t. I moved on to Kodi, and found that didn’t work well either. Still looking for a good solution to stream to Chromecasts - that’s the best solution I can think of for my use.
I’m going this way:
1st: Render web page to stream
2nd: Stream to chromecast
Not sure it’s the most elegant. Would be way better if chromecast had a command line switch to turn cast on.
